While backing up my DVD collection I came across Pulp Fiction lately. Source is DVD R2, not interlaced. Here goes my backup experience step-by-step...
First try with tool #A: AnyDVD
- AnyDVD detected disc
- used DVDShrink to copy main movie: I/O error, DVD structure not readable (something like that)
- used CloneDVD: copy successful
- used DGIndex to index: source interlaced and bad field order
- deleted files
- used DVDDecrypter / Ifo Mode: copy successful
- deleted files again
- shut down AnyDVD
Quite bizarre...
Second try with tool #B: DVDFab HD Decrypter
- tool detected disc
- copied main movie: successful
- used DGIndex to index: source progressive
As expected...
Anybody have an explanation for this odd decryption behavior? Basically, I thought AnyDVD to be the most reliable decryptor.
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
I'm not convinced the makers of AnyDVD know anything about other software. Just yesterday I ripped a disc to an image and it warned me that if I need to do further work to the DVD (with something like DVDShrink) that I should output to folders instead....implying that DVDShrink does not open image files.
Actually, I have found that AnyDVD does require ripping to files rather than to an image to repair structure protection. If you insist on ripping to an ISO image when AnyDVD says it detected structure protection, the ISO image still contains the protection.
If AnyDVD says "Structure protection not found" I rip to an ISO image. If AnyDVD says "Structure protection found" I rip to HD files and then use ImgBurn or DVD Shrink to create an ISO image. I can't recall the last time this failed to work for me, but I'm pretty sure it was only until the next release of AnyDVD handled that particular structure protection properly.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
IsoBuster with AnyDVD / DVDFab Pk
By leghorn in forum Blu-ray RippingReplies: 5Last Post: 2nd Apr 2012, 22:26 -
DVDFab or AnyDVD HD?
By Killingtime01 in forum Newbie / General discussionsReplies: 10Last Post: 18th Mar 2011, 21:01 -
Which program to buy/use DVDFab, anydvd or are there others that are better
By busterbrown885 in forum DVD RippingReplies: 6Last Post: 11th Nov 2008, 19:06 -
Which is better DVDfab or AnyDVD/CloneDVD?
By Vrex in forum DVD RippingReplies: 17Last Post: 23rd Mar 2008, 21:46 -
anydvd + dvd decrypter or dvdfab?
By jamescardenas07 in forum DVD RippingReplies: 27Last Post: 15th May 2007, 20:29
