Here is media info of movie i've burned to dvd using nero express as data dvd. Can anyone give me any ideas y it wont play. thanks
General
CompleteName : C:\Users\Claire\Videos\The Adjustment Bureau (2011) DVDRip XviD-MAXSPEED\The Adjustment Bureau (2011) DVDRip XviD-MAXSPEED www.torentz.3xforum.ro.avi
Format : AVI
Format_Profile : OpenDML
Format_Settings : rec
FileSize/String : 1.47 GiB
Duration/String : 1h 45mn
OverallBitRate/String : 1 990 Kbps
Encoded_Application : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
Video
ID/String : 0
Format : MPEG-4 Visual
Format_Profile : Advanced Simple@L5
Format_Settings_BVOP/String : 2
Format_Settings_QPel/String : No
Format_Settings_GMC/String : No warppoints
Format_Settings_Matrix/String : Default (H.263)
CodecID : XVID
CodecID/Hint : XviD
BitRate/String : 1 537 Kbps
Width/String : 720 pixels
Height/String : 384 pixels
DisplayAspectRatio/String : 1.875
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Compression_Mode/String : Lossy
Bits-(Pixel*Frame) : 0.232
StreamSize/String : 1.14 GiB (77%)
Encoded_Library/String : XviD 1.2.1 (UTC 2008-12-04)
Audio
ID/String : 1
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
CodecID : 2000
BitRate_Mode/String : Constant
BitRate/String : 448 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
StreamSize/String : 339 MiB (23%)
Alignment/String : Aligned on interleaves
Interleave_Duration/String : 64 ms (1.53 video frames)
Interleave_Preload/String : 192 ms
Title : The.track_2
Closed Thread
My dvd player. It will play xvids burnt using nero express - data disc. Any ideas?
So you pirated a movie and now your asking why are you having trouble converting pirated movie to a DVD that will play in your DVD player.
I have a bunch of friends who do the same crap, one of the primary things I have seen with them is disk comparability. They're to cheap to buy the movie and so naturally they also skimp on media and buy cheap store brand DVD-R. And if you purchased DVD+R back in the day you cold change the book type to make it more compatible with players.
I personally think the Nero is crap and have seen it be the root cause of many problems, a lot of bad burns (switch to ImgBurn). I have also seen Nero fail to make compliant DVD I don't know if there was an issues with the mpeg files themselves or if the DVD structure was non-compliant. I know that Nero use ti have problems with non-compliant\hacked avi streams. Swithc to a differtent tool to encode your video files, HcEnc, Quenc or CCEbasic then author DVD with DVDAuthorgui, multiAVCHD or DVDLab.Murphy's law taught me everything I know.
sweetcheeks82, Do not link to WAREZ sites. Buy the movie. This thread is closed.
Moderator redwudz
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
xp wont play movie
By natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 13:26 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37 -
a 700 mb movie burned in 1 cd would it play on DVD players
By ianskiee in forum Newbie / General discussionsReplies: 5Last Post: 10th Jul 2007, 13:05
