Hi,
I'm using Jubler with MPlayer - I'm loading avi video but when the programme opens it doesn't look as in the tutorial pic:
i.e the blue Waveform on right side of display (2) above is absent on my view - that side of the screen is filled with subtitle text lines. Immediately below the preview picture on the left I have a kind of waveform with blue and green bar, ie, just the lower part of the waveform display with the gray ruler bar.(From the point of the arrow on the picture to the bottom of the waveforrm window) I'd prefer to work with waveform as shown above.
Is it a setting issue - have I switched something off. The 'enable/disable waveform preview' and 'maximise waveform visualisation' buttons dont seem to be working. Should I save the subs I have made too a pendrive and uninstall/reinstall Jubler prrogramme? Using Win XP Sp3 machine by the way.
Note: I just detached the 'subtitle editor' window which caused the waveform to appear beneath my video preview window - I can work with it like that. The trouble is - having detached it - not sure how to attach it again! (it seems to go back when you save-close-open) I would like to get a display like the one above if possible. Any advice gratefully received.![]()
Results 1 to 1 of 1
Having trouble burning subs created with Jubler......
By bahjan in forum SubtitleReplies: 3Last Post: 29th Sep 2011, 08:54 -
Jubler not showing different fonts in preview nor burning with DVD Flick
By bahjan in forum SubtitleReplies: 2Last Post: 25th Aug 2011, 15:07 -
Win 7 sp1 update views
By johns0 in forum ComputerReplies: 8Last Post: 27th Feb 2011, 00:56 -
Downloading (not updating) Jubler for Windows?
By Aikousha in forum SubtitleReplies: 2Last Post: 9th Nov 2010, 18:43 -
Post counts and thread views
By Supreme2k in forum Off topicReplies: 3Last Post: 28th May 2009, 08:14
