Is there a way to hardsub an MKV file while maintaining the subtitles styles and placement but without rencoding the the video file? I've know of ways to do it but it means converting the file to AVI or MP4. .
I already know how to extract the subs and such so I'm sorted on that end.
Thanks in advance for your help.![]()
Hard coded subs become part of the video stream, re-encoding is the only way.
You don't have to change your format you can have a mkv with hard subs. but a better option may be to use MKVmerge to change the subs t forced subs. So the subs are turned on by default.Murphy's law taught me everything I know. -
Ah that's a shame. My TV only reads .SRT and refuses to regonize fonts and the placements of text so sometimes things get jumbled up at the bottom. Thanks for the help anyway.
Ah, I see. So, basically, your MKV has one or more ASS/SSA-format subtitle streams, which your TV doesn't support - but you'd like to be able to view them on the TV. Unfortunately, it only supports SRT format subs, and, of course, converting ASS/SSA (or any other similar format) to SRT will lose all the formatting, placement, effects, font styles, etc.
I don't think there's a way around this without hardsubbing the video (meaning you'll have to re-encode), as your TV doesn't support any other format of subs.If cameras add ten pounds, why would people want to eat them?
hardsubbing xmediarecode
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2011, 09:49 -
Hardsubbing AVI and ASS subtitle
By lonelyassassin in forum SubtitleReplies: 2Last Post: 9th Jan 2010, 11:30 -
Problems in Hardsubbing
By CTECH in forum SubtitleReplies: 5Last Post: 6th May 2008, 09:01 -
Sub will not show on Hardsubbing
By arabian in forum SubtitleReplies: 0Last Post: 1st Jan 2008, 07:14 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 17:32
