What is the best way to accomplish this? I have been doing some research and it seems to be the best way to convert a standard 16:9 DVD to MP4 (or MKV) H.264 without resizing to get better quality. Are there any guides for this? The file size is not an issue, as long as it fits on a single layer disc.
Thanks, Ally!
Results 1 to 11 of 11
Are you sure you want anamorphic video? Anamorphic is designed to to stretch the video's width or shrink the video's height to fit the display unit the video is being displayed on, hence the video really doesn't have a native width and height.
here is a handbrake guide that details the various methods to encode anamorphic video.
https://trac.handbrake.fr/wiki/AnamorphicGuide#visualMurphy's law taught me everything I know. -
I thought it doesn't stretch the video but I may be wrong. Is there a way to just encode to get rid of the black bars? Or is that even possible.
I always leave the frame size the same as the DVD except for cutting away the black bars in the source. Then set the encoder's and/or container's pixel aspect ratio or display aspect ratio flags. That way there's no loss of resolution. Just be sure your playback device(s) support aspect ratio flags.
Ditto Jagabo.
Ally68, I can't speak for Jagabo the main reason I chose to do it manually, is to achieve the best quality this is something that is hard to do with one click tools. If you choose to use handbrake you can disable anamorphic by clicking the picture tab and from the Anamorphic drop down select none. Make sure to check the box "keep aspect ratio". If "Cropping" is set to automatic handbrake will crop out the black bars.Murphy's law taught me everything I know. -
Sure encode it keeping in mind that to get rid of the black bars you either have to distort the video or cut part of it off. If the bars are top and bottom cut off the ends.
This method means you lose things on the sides of the screens.
or if the bars are the sides cut off the top and bottom.
This method means you may be cutting off feet and the tops of heads.
Or just encode to fill the screen without cutting. Then you can have either short fat people or super skinny to tall people.
Myself I'd rather have the bars.If I'd known I was going to live this long, I'd have taken better care of myself. -
Note that widescreen TV screens have a 16:9 aspect ratio. That is not a common movie aspect ratio. Common movie aspect ratios are 1.33:1, 1.37:1, 1.66:1, 1.85:1, 2.20:1, 2.35:1, and 2.4:1. So almost any movie you watch should have some black bars at the edges. The exception would be made for TV movies and modern TV series. Many computer monitors (and some TVs) have a 16:10 aspect ratio, not 16:9. So even 16:9 video should have black bars on those TVs.
http://www.widescreen.org/aspect_ratios.shtmlLast edited by jagabo; 18th Aug 2011 at 16:50.
Please talk about Anamorphic resizing
By kenryuakuma in forum DVD RippingReplies: 3Last Post: 2nd Sep 2011, 18:55 -
A few questions on Anamorphic encoding
By scubasam in forum Newbie / General discussionsReplies: 10Last Post: 31st Mar 2010, 22:04 -
Resizing anamorphic HD video in Megui
By Bully9 in forum Video ConversionReplies: 7Last Post: 10th Mar 2010, 22:26 -
Question I've not seen asked about anamorphic encoding
By mike81 in forum Video ConversionReplies: 2Last Post: 7th Nov 2009, 22:02 -
MeGUI - Clever Anamorphic Encoding?
By bullet_ballet in forum Newbie / General discussionsReplies: 1Last Post: 2nd Sep 2007, 23:29
