I'm getting crashes with the latest version of VLC, 1.1.11. I think these occur if I close VLC by clicking the top right 'X' icon. After that I see the VLC icon in my XP system tray but I cannot exit from it. I'm forced to use Task Mgr.
Anyone else seeing similar behaviour please?
Terry, East Grinstead, UK
	Just tried it v. 1.1.11 on my XP Home netbook, no problems. I use it on other XP Home and Pro desktops: No problems.
	Thanks for testing it. I'll try to pin down more facts and come back.
	Have you tried resetting your preferences? (You're usually given the option on install, or you can go to Tools > Preferences and click on the Reset Preferences button at the bottom of the window. That will reset all your settings/preferences to their default.) Sometimes, existing preferences can cause problems/become messed-up when you install a new version of VLC over an existing version.
 If you'd rather not erase/reset the preferences until you're sure, go to the Start menu > Run... and enter "%appdata%" in the Run box (without the quotes), and press Enter. In the Explorer window that pops up, find the folder named "vlc" and rename it, then open VLC, and see if the problem persists.If cameras add ten pounds, why would people want to eat them?
  VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 22:34
  VLC installation crashes PCBy hungledink in forum Software PlayingReplies: 1Last Post: 29th Nov 2009, 12:30
  no vhs closed captioningBy marvinwc in forum Newbie / General discussionsReplies: 8Last Post: 16th Oct 2009, 19:32
  MPC crashes Ati video driver - VLC doesnt?By snadge in forum Software PlayingReplies: 1Last Post: 29th Jul 2009, 13:42
  Closed GOPBy kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
