i have begun (late) my ipod touch v1 to learn about moving video files to such devices in prep for an iPad at some point.
I use elgato turbo.264 HD and videora for most transformations but neither seem to like wmv files. the iTunes lib and pod dont like them either.
is there a freeware/shareware program that can prep these files so either of the two programs above can deal with them?
QT takes the wmv and can copy and past ending up with a .mov but that files is also disagrees with what I have.
Handbrake also finds them unappetizing.
	MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 QTPro, MPEG2 add on MPlayerX2
 MPEG Streamclip
 24 + 21" samsung flat panels
 G4dual 2GB
 AlchemyDVR card
	Try another ffmpeg frontend like ipodme, xmedia recode, freemake video converter. Use a ipod profile.
 If it wont work post the details(audio and video codec) from the wmv. Use mediainfo.
 edit: OOps. I should have mentioned some mac ffmpeg frontends like Smart Converter.Last edited by Baldrick; 17th Aug 2011 at 13:31.
	While the Flip4Mac commercial program works, it's quite expensive.
 What I use is the free MovieMaker in Windows7 running in Parallels. That converts the WMV to AVI and the resulting video may then be converted using the Turbo264 hardware/software -or- Handbrake -or- QT Player Pro (assuming you have installed the free Perian plugin).
 Free? No. One step? No. Works? Yes.
 If you have the free Flip4Mac plugin, you should be able to use QT Player Pro to export to H264 -but- you will have the Flip4Mac watermark (and, possibly, the length of the video may be limited - don't remember).
	many thanks. ElGato does put the watermark on the vids.
 ill fiddle fiddle some more and add some media info later.
 kudos to all!MPro 2.66 3GB RAM 1.5TB HD's
 MigliaMiniHD
 MPEG Streamclip
 G4dual 2GB
 AlchemyDVR card
	I think AVIDemux also has some support for WMV files - I used the Windows version to handle some, a while back. Not sure if the OS X version will do it, though (I'll have to test). I believe AVIDemux also has an iPod output preset. If cameras add ten pounds, why would people want to eat them?
	"Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
  Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04
  App for converting my WMV encoded file for iPod?By Jeikobu in forum MacReplies: 16Last Post: 25th Feb 2010, 17:59
  Unable to convert some WMV files to Ipod Touch format - Why?By tradertt in forum Video ConversionReplies: 14Last Post: 8th Oct 2009, 05:22
  HD WMV w/5.1 Sound Conversion to iPod Format Problem -- Help Please!By VixenofVenus in forum Video ConversionReplies: 10Last Post: 2nd Oct 2008, 13:59
  Converting wmv to ipodBy hunkofla in forum ffmpegX general discussionReplies: 1Last Post: 10th Jul 2008, 20:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
