I tried converting FLV files to VOB using convertxtodvd so that I can watch them on dvd player but it seems that convertxtodvd cant convert flv files!!Someone help me![]()
Results 1 to 12 of 12
I can't live without my computer.
I try my best to stay a way from 1 click tools, anytime they are thrown a curve ball they tend to choke and die. Know the process and having the skill to perform it manually is always best method. Not that you always have to do the conversions manually but at least you have your options open.
But to answer your question If the flv to dvd process is giving you issues I would convert to avi, you'll find more tools that can convert avi DVD. Heres a guide to get you started: https://www.videohelp.com/guides/flv-to-avi-conversion-guide-using-virtualdub-id935#935Murphy's law taught me everything I know. -
Try another 1 click tool. Freemake Video Converter or AVStoDVD.
I have had this problem a couple of times with convertxtodvd.
Each time it was easily solved by simply updating my system's video codecs. -
It works now but I also have another problem. It only converts 3 videos!!I tried loading 6 and then 5 and then 4 videos but each time, it only conerted 3 videos. When it started to convert the fourth video, it stopped and the process was done. In the end, the result was a 2.3 gb DVD. But this never happened before.
I can't live without my computer. -
Maybe you will get better help with convertxtodvd in http://forums.vso-software.fr/ . Be sure to include as much details about the problem as possible.
Sounds like you have altered the programs parameters. Try resetting to defaults:It works now but I also have another problem. It only converts 3 videos!!I tried loading 6 and then 5 and then 4 videos but each time, it only conerted 3 videos. When it started to convert the fourth video, it stopped and the process was done. In the end, the result was a 2.3 gb DVD. But this never happened before.
1. In 'Settings' click on 'Reset form positions'.
2. in 'Settings>DVD menus', in the sub menu click 'Reset to VSO defaults' button.
See if that works. Good luck. -
I am using convertxtodvd version 2. There is no "Reset form positions" under settings.
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 13:53 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
What's the best FLV converter + best method to create FLV's from pure video
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 31st Mar 2008, 19:23 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11
