Hello everyone,
I got material as a fcp-file and I downloaded avidemux (my system is Windows XP). Does anyone know what I have to do to to be able to open the fcp-file so that I can work with it?
Thanks!
rh
if you are using a mac and have final cut pro you could convert it. it isn't available for a pc.
Need for definition than that. Try asking the person that sent it or see if Mediainfo accepts it.
http://www.kiva.org/about
IVTC a vob/m2v file before FCP editing
By kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 03:15 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 16:59 -
FCP not recognizing a XML file
By lcquintana in forum MacReplies: 0Last Post: 17th Oct 2008, 13:54 -
FCP Render File Problem
By James in HD in forum MacReplies: 4Last Post: 8th Jan 2008, 10:21 -
how to play QT file( DV-DVCPRO 29.97 ) in FCP without PULLDOWN
By Radoje in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jan 2008, 21:50
