Results 1 to 9 of 9
  1. Hi friends. Could you please help a noob out??
    I use ripbot 264 for converting 700 MB.avi files to 300 to 400MB .mkv
    The problem I am facing is that sometimes,with certain files, ripbot does not mux the audio with video however the audio stream is extracted properly and I can also see a video file being created in the temp[Ripbot] folder. Both files sit in the folder but they are not muxed by ripbot. What should I do to resolve this? This does not happen with all files but only with a few.
    Give more info about the avi source. Use mediainfo.
    Or try handbrake.
  3. Member dragonkeeper's Avatar
    Jul 2003
    Go with Baldrick suggestion switch to Handbrake.
    For the files you have already converted i would extract the audio from the original avi then mux the audio with the avi file created by ripbot264.
  4. Thanks for the quick reply. Heres the mediainfo:
    General
    Complete name :UFC 16 Part 1.avi
    Format : AVI
    File size : 698 MiB
    Duration : 58mn 3s
    Overall bit rate : 1 681 Kbps
    Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
    Writing library : VirtualDubMod build 2540/release
    Video
    Format : MPEG-4 Visual
    Format profile : Advanced Simple@L5
    Format settings, BVOP : 2
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : XVID
    Codec ID/Hint : XviD
    Duration : 58mn 3s
    Bit rate : 1 480 Kbps
    Width : 512 pixels
    Height : 384 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.301
    Stream size : 614 MiB (88%)
    Writing library : XviD 1.1.0 (UTC 2005-11-22)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 2000
    Duration : 58mn 3s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Delay relative to video : 686ms
    Stream size : 79.7 MiB (11%)
    Alignment : Split accross interleaves
    Interleave, duration : 40 ms (1.00 video frame)
    Interleave, preload duration : 500 ms
  5. Member dragonkeeper's Avatar
    Jul 2003
    Based off the information displayed by media info i don't see anything wrong. It appears to have an ac3 audio file of 79 MB in the avi container.
    Questions that come to mind.
    1.Which player are you using to play the file?
    2. have you tried turning up the volume? (most often AC3 will be play considerable lower than it's mp3 counter part)
    3. Do you have an AC3 codec install on your system? (ac3 Filter, ffdshow).
    4. Have you tried to de-mux the file and play the audio stream separately?
    Murphy's law taught me everything I know.
  6. Originally Posted by dragonkeeper View Post
    1.I Use GOM player and VLC and I have no problems in playing the source file.
    2.Works fine.
    3.Yes
    4.Thats the problem that ripbot 264 is not muxing the audio and video stream after conversion. Both files sit in the Job Folder at the end of the conversion process.
  7. Member dragonkeeper's Avatar
    Jul 2003
    Ripbot264 crashes on my box when de-muxing audio so i switched to Megui and in some cases i use handbreak. Have not had any issues with either of these products.
  8. Originally Posted by dragonkeeper View Post
    Would try Megui as you said. Can you specify output file size in megui?
  9. Member dragonkeeper's Avatar
    Jul 2003
    Yes, use the built in calculator to calculate the bitrate need to achieve the desired file size, the apply the settings. Don't to forget to account for the audio file size.
