    Dec 2010
    quebec
    off topic , this must be the place
    i heard of placing them between 2 glass in the sun .. some ever say oven !?
    some say hot water ,, some clamp them to the turntable ..
    have any of you ever did anything that really works ?
    May 2001
    What's a vinyl record?
    Just kidding!
    If the records will not play, then what do you have to lose? I would try the two pieces of glass in the sun. However, I would monitor the progress very closely, because any heat that will "unwarp" the platter can also deform the tracks.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
    Bake it in the sun? No, I wouldn't. I would think that may do damage.
    I'd opt for a hairdryer or heat gun held at a good distance for a short burst of time.
    I've not had to do anything like this because warped records can still play.
  4. Get a turntable with a clamping spindle. The ones with a threaded spindle will allow you to screw a clamp down on the center hub of the record. It squishes the record flat for playing. Unless it's badly bent this will work fine.
    "I've not had to do anything like this because warped records can still play"
    Usually true, but if it is warped bad enough, you can hear the warble in the speed when the needle goes up and down hill.
  5. Member olyteddy's Avatar
    Dec 2005
    I used to have a WinAmp plug-in that would emulate warped and scratched Vinyl: http://www.winamp.com/plugin/izotope-vinyl/39214
  6. Member Rosc0PColtrane's Avatar
    Sep 2011
    With the good ol boys
    Two bits of glass method is genuine. Though not sure about putting them in the sun. I used to put mine in the airing cupboard (a heated cupboard for towels). Had mixed success.
  7. Member zzyzzx's Avatar
    Baltimore, MD USA
    I'd throw out any warped vinyl records.
  8. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    I tried the 2 glasses and sun approach; it didn't work for me. Eventually I had to use a hair dryer to heat it up, then used the glass to apply pressure to flatten it again. Worked just fine and plays perfectly. Now I have The Wall on vinyl and only paid $3 for it.
