I have a HD movie in m2ts format and I would like to convert it to a format readable by the Blu-ray and DVD players. I understood I can maintain the quality only for the Blu-ray conversion. How can I make these conversions, what software to use?
Thanks!
Results 1 to 11 of 11
If you want to keep the quality it wont work on standard dvd-players. Use for example tsmuxer or multiavchd. Output as avchd. Burn on DVDR with imgburn.
If you want it to work on standard dvd players you must convert to dvd-video, use for example freemake video converter, avstodvd or Blu-ray Converter Ultimate. -
Thank you very much for the answer! One more question: in order to get the DVD format do I have to convert first m2ts to avchd or can I make the conversion directly from m2ts (using the software you suggested) ?
I converted the m2ts video to AVHCD using tsmuxer. Then I tried to burn it on a DVD+R DL disc (Verbatim) using Imgburn. Unfortunately it failed and moreover afterwards I could not read any CDs/DVDs in my Blu-ray drive (of a Sony Vaio laptop). I did a system restore to an older date when the drive worked, but it did not help. Now I've sent the laptop to Sony for repair.
However, I'm wondering: was it just bad luck or... could it be that the drive thinks it has to burn a bluray disc, while actually it has a DVD-DL inside? From Sony CS I understood there are 2 lasers in the drive: one for CDs/DVDs and one for bluerays. Is there a possibility that the drive gets confused and as a result it gets broken (by using the "wrong" laser)? I'm asking all that because I would like to try again when the laptop is fixed, but I don't want to end up (again) with a broken blu-ray drive. -
I don't think that's EVER possible for any Blu-ray burner to ever do that. It most likely was a Hardware defect, or a Windows error.
FYI: Whenever you Right-Click -> Properties ANY M2TS video in Windows 7 (or Vista), it will ALWAYS say "AVCHD Video". Why try to re-convert a video to its' original format? Makes no sense.
If you wanna make the file readable on Blu-ray Players, then use TsMuxer & choose "Blu-ray Disc" as your output. If you wanna make the file work on DVD players, then the ONLY way to do that is to: A. Lower the quality of the video to something that can fit on a DVD+_R DL (480p?), B. Re-Mux the video to DVD-style folders, & C. Burn the files using ImgBurn.
Just use Freemake Video Converter to convert the files to DVD-style VOB w/ folders & then just burn the files using ImgBurn... -
NOTE: Haven't tried yet, but Freemake Video Converter might also be able to burn the disc directly after converting (?).
Why is it that with every piece of software, if I try to encode a m2ts (avchd) or a mkv (x264) to dvd format, the output file looks blurry and with a lot of noise? If I convert the m2ts to x264 or even xvid (in avi), the video looks great at that given resolution (let's say 624 x 352 for xvid).
I use VSO ConvertXtoDVD to convert a blu-ray .MSTS file to a DVD disc so that it will play in any blu-ray/dvd player, it will also happily convert an MKV or AVI or MP4 rip so you shouldn't have too many problems with common video formats it can't handle
It can also easily handle forced subtitles and subtitles and more importantly actually keep the audio and video in synch, which a lot of software just can't manage all the time
As you are converting from a blu-ray rip the final quality will be much better than a DVD of the same film, but be aware it has a lot of work to do to convert a file that could be anything from 4.3GB to 25GB to DVD specs
On my old Q6600 it used to take about 2-3 hours to convert a full 1920x1080p blu-ray rip to a PAL DVD, the same software will also quite happily burn to a blank DVD for you. Make sure you burn it at a maximum of x8 as some DVD players struggle to play DVDs that have been burnt as past as possible. Besides you are only saving about 3-4 minutes and saves having to re-burn it if it starts skipping or stuttering due to being burnt to fast -
As for poor quality, you can only get what you give the software. Some are terrible at converting AVI's back to DVD, again I found ConvertXtoDVD was one of the better ones, they get their speed from cutting corners on quality, which is what you have found
One of the better pieces of software is HCEnc, its slow for a reason. Not because its badly coded but quality takes preference over speed. Have a look at AVI2ISO, its free and can use HCEnc as its encoding software, or AVI2DVD which is again free -
Blu Ray Converter DVD - cheaper than the Ultimate but, does not do MKV, MP4, etc.
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
burn m2ts to blu ray without reencoding?
By dashley in forum Newbie / General discussionsReplies: 5Last Post: 22nd Sep 2011, 18:40 -
can't create a blu-ray disc from m2ts
By hunter2155 in forum Authoring (Blu-ray)Replies: 4Last Post: 14th Aug 2011, 07:15 -
Ripping a Blu-ray and M2TS is in French... help
By Quartechs in forum Blu-ray RippingReplies: 1Last Post: 25th Jul 2011, 14:02 -
Editing M2TS Blu-ray Files?
By ScaryRobot in forum EditingReplies: 4Last Post: 21st Oct 2009, 21:08
