Hey guys just trying to extract DTS-HDMA track to WAV. I think I've got it right, can someone take a look at my log and see if I'm actually decoding the HDMA track and not the DTS core?
cheersCode:M2TS, 1 video track, 5 audio tracks, 11 subtitle tracks, 1:53:24, 24p /1.001 1: Chapters, 24 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 4: AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 5: AC3, Italian, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 6: AC3, German, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 7: AC3, Spanish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB 8: Subtitle (PGS), English 9: Subtitle (PGS), English 10: Subtitle (PGS), French 11: Subtitle (PGS), Italian 12: Subtitle (PGS), German 13: Subtitle (PGS), Spanish 14: Subtitle (PGS), Dutch 15: Subtitle (PGS), Swedish 16: Subtitle (PGS), Danish 17: Subtitle (PGS), Norwegian 18: Subtitle (PGS), Finnish [a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [a03] Writing WAVs... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.L.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.LFE.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.R.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.C.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.SR.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\1_3_audio.SL.wav"... [a03] The original audio track has a constant bit depth of 24 bits. Video track 2 contains 163140 frames. eac3to processing took 7 minutes, 8 seconds. Done.
Results 1 to 9 of 9
One more question, do you know if the decoded output(ie wav, lpcm) has Dialog Normalization applied?
For example say a DTS-HDMA or Dolby TrueHD track has a DialNorm value of -27dBFS will the decoder drop the levels by 4dB to comply with the Dolby spec of -31dBFS DialNorm output. Will it apply for both tracks, just Dolby or none?
cheers -
IF the DTS-MA source has more channels than its "core",
AND eac3to decompresses as many channels as the DTS-MA source contains,
then you're lucky. Otherwise, it's like waiting for the turn of a friendly card.
FYI, there is a very-convoluted method suggested in this Doom 9 thread,
http://forum.doom9.org/showthread.php?t=162162
maybe it will work for you.
The only thing is my Arcsoft decoder is set to output 5.1 not 7.1 so if I run decode a DTS-HDMA 7.1 track to wavs I'll get 5.1 either way, in other words the test you suggest will not prove one way or the other in this situation.
I opened up C:\Windows\win.ini in notepad:
Here's what the 'AudioOutputMode' values mean:[HKEY_LOCAL_MACHINE\SOFTWARE\ArcSoft\MPEG Codec\Decoder Setting\]
AudioOutputMode=13
AudioDynamicRange=0
0,1,2,5: Stereo
6,13: 5.1 Channels
17: 7.1 Channels
16: S/PDIF
I'm not sure how to change the value, I tried changing it to '17' and closing notepad which asked to save but it looks like it wants to save as .txt not .ini
cheers -
It seems to be an issue with mounting the BD ISO in Virtual CloneDrive and not an issue with eac3to and HdBr Stream Extractor. I just extracted a DD track from a BD in file format and it worked properly. Might have to try another virtual mounting program.
cheers -
Scratch that, I just extracted the full 8 channels of a DTS-HDMA 7.1 track to separate WAV files and the surround back(BL & BR) wav files have content in them. So it seems the above setting is overridden or does not affect eac3to.
Here's the log:
Code:M2TS, 1 video track, 5 audio tracks, 5 subtitle tracks, 2:05:09, 24p /1.001 1: Chapters, 20 chapters 2: h264/AVC, 1080p24 /1.001 (16:9) 3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 4: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz 5: AC3 Surround, English, 2.0 channels, 320kbps, 48kHz 6: AC3, French, 5.1 channels, 640kbps, 48kHz 7: AC3, Spanish, 5.1 channels, 640kbps, 48kHz 8: Subtitle (PGS), English 9: Subtitle (PGS), French 10: Subtitle (PGS), Spanish 11: Subtitle (PGS), French 12: Subtitle (PGS), Spanish [a03] Extracting audio track number 3... [a03] Decoding with ArcSoft DTS Decoder... [a03] Writing WAVs... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.SL.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.BL.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.L.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.R.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.C.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.BR.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.LFE.wav"... [a03] Creating file "F:\BD Ripping\HdBrStream\Tron Legacy\1_3_audio.SR.wav"... [a03] The original audio track has a constant bit depth of 24 bits. Video track 2 contains 180028 frames. eac3to processing took 29 minutes, 52 seconds. Done.
eac3to: DTS-HD MA (Arcsoft) -> W64, clipped the center channel
By Asterra in forum AudioReplies: 1Last Post: 19th Apr 2012, 01:37 -
eac3to: error converting 6.1 ch DTS -> AC3
By KushSmoka420 in forum AudioReplies: 5Last Post: 6th Mar 2012, 10:35 -
Error while decoding stream #0.0
By brassplyer in forum Video ConversionReplies: 0Last Post: 26th Aug 2009, 05:04 -
eac3to conversion- thd->dts
By runLoganrun in forum AudioReplies: 0Last Post: 16th Dec 2008, 12:47 -
DTS Decoding
By Neutral-Sage in forum AudioReplies: 8Last Post: 17th Nov 2007, 02:16
