I have two AVI's one long one & one very short one. I am trying to get the short one's framerate to match the long one. But Mediainfo, Virtualdub, even Boilsoft Video Joiner says everything matches & I have tried using AVIDEMUX, Virtual Dub, Virtual Dub MOD to change the framerate of the short one but it does not seem to be updating that it changed & I still get the same error when I try to merge. What is wrong here ?
The files must have the same frame rate AND...
--- same frame dimensions
--- same video codec
--- same audio codec
Regarding the change of frame rate, there exists a command-line tool called tc2cfr.exe, written by a guy named tritical. -
If VirtualDub gives an error message that lists the framerates with two different hex value ratios (which in decimal give the same result), load each file one at a time in VirtualDub and 'Convert to fps' and insert a value like 25, then save each file with Direct stream copy.
Try and join again and convert back to the original framerate.
How to sync subtitiles to match Video/Audio
By VidHunter in forum MacReplies: 3Last Post: 17th Nov 2010, 16:55 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 05:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 20:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 07:35 -
Conversion of audio to match video
By deltaromeo in forum AudioReplies: 11Last Post: 29th Jan 2008, 13:01
