Hi,
I tried to play a BR-DL on my LG BD370 but... it gave a disc error while it plays smoothly on my PS3. My question is:
Does it actually support blu ray DL (as some plp in some other forums confirmed that it plays DL)?
Is it a SW issue ?
Any help would be great
Results 1 to 13 of 13
Have you just tried one br-dl brand?
And please don't cross post. I deleted your other thread. -
Thanks man for deleting the other post... appologies
I burnet a DL BR on a Sony BD DL and did not work on the LG and gave "Disc error" ... but on PS 3 it worked. On the specs page found here, it said that this player plays BD DL -
Had the same problem on a LG BD590 not playing a BD9 disc but would play a BD5. After updating the latest firmware and servo update a month ago, it plays BD9 discs.
Under Software Information for the BD590, it lists MAIN VER and SERVO VER. The Servo update is a driver update for the disc reader. In my case the servo update did the trick.
Your player may not have a seperate servo update. -
It looks like there are no servo update for my player...So i guess it does not play BD-DL
Just a quick update... LG BD 370 plays perfectly BD DL. When i switched brands from TDK to Verbatim, it played 100%.
I am just sharing my experience... 5 TDK BD DL went damaged while burning them while Verbatim BD DL very soft and none of them were damaged. Anyways it is not an ad.. it is just to confirm that it plays BD DL.
By the way, if you have other TDK BD DL discs to use up, try burning them at lower speeds. You might try 4x or even 2x and see if that does any better for you. Sometimes lower quality discs will burn successfully at lower speeds.
Not to digress, but all the BD media I've seen in stores was made in Japan. Are we at the point with BD media where "made in Japan" may not necessarily be an indicator of quality? I am asking because I honestly don't know. -
I tried at several speeds even 1. Honestly to make things clearer, i used a monster USD cable to attach my BD burner to my laptop instead of the crap cable that comes with the LG external burner. I think this made a huge difference in reading the DVD's and BD'S. I am honestly not sure but 5 TDK getting damaged on diff speeds ... that's a fortune for a BD DL man...
help on Oneforall URC-7960 to unlock Sony BDV-370
By azuma in forum DVD & Blu-ray PlayersReplies: 4Last Post: 4th Aug 2015, 15:20 -
Can't seem to get hack right: LG BD 370
By rjl24 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd Jun 2010, 08:53 -
LG BD 370 Blu Ray
By ARTHURHOFMAN.NL in forum DVD & Blu-ray PlayersReplies: 8Last Post: 14th Feb 2010, 05:57 -
Sanyo DWM-370, region hack question
By Akabane Kurodo in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Aug 2009, 12:40 -
How can I find a Sanyo DWM-370 DVD Player???
By Akabane Kurodo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Jun 2008, 10:00
