  1. Hi,
    I have an external LG BP 06LU10. I have severe difficulties writting on most of DVD DL , BD-DL and DVD-R. I am not quiet sure about the reason but I am running on Toshiba with Windows 7 Pack 1 Intel Core Duo 2 (4GB) 32 bit. I am not sure wether it is a problem of conflict with a progrom or wondows or what...
    In my toshiba, the imgburn just keep on writting "setting L0 Zone...." forever. while the burner cannot feel most of the DVD-R and BD DL.
    I tried the external on my new Dell and it started burning than it gave an error after 4% of writting a DVD DL.
    I am using Sony DVD+DL and trying to burn usual Video TS files downloaded from trused source.
    I then tried the internal burner of my Dell with the same DVD and it worked like charm and very fast in burning using same DVD DL
    I am quiet confuse about this product and I need to know what is going wrong... is it something in windows with the external... a program running that make the problem or what ???
    Hellllllllllllllllp please
  2. Ok guyz... it was my mistake... the USB cable that i used was somehow weak.. I switched to a monster USB cable and it recorder BD DL like a charm...
