I'm not too sure what the SBC format is, I think it has something to do with Smart Bitrate Control or something. Anyways, I have a movie that is in the sbc format when I try to use TMPEG encoder to convert to vcd I get no audio from it, it will only decode the video. I used Virtual Dub to get the audio from the movie and it worked with one exception. The original movie has about a three second silence in audio when it starts (I'm guessing when someone encoded it they did that so that their audio would be in sync with the movie). So when I use virtual dub to get the audio it doesn't include that 3 second sound delay and the audio is off in my finished movie. Is there a better way to do this. Can anyone help.
Results 1 to 1 of 1
Can you make a Blu-Ray with MPEG2 format?
By faramith in forum Authoring (Blu-ray)Replies: 5Last Post: 18th Jan 2011, 02:39 -
Best format to copy VHS and DVC's (mini) to make sure they'll last?
By shaytala in forum Newbie / General discussionsReplies: 3Last Post: 12th Sep 2010, 14:53 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 06:14 -
How can i make subtitle bigger or smaller (SUP File Format)
By Charmer in forum SubtitleReplies: 9Last Post: 2nd Jun 2009, 15:43 -
how to make sure that your output format for autogk is either, avi, mpeg..
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2007, 07:00
