I need to convert a lot of dvd video (VIDEO_TS) files to a single .mpg files..
I am trying to use VideoReDo because it doesn`t re-encode the video, and is very fast. But it also unreliable as it won`t read a lot of files and crashes a lot..
Are there any other software that would allow me to trim and cut media (not only beginning and end), and just save to .mpg without re-encoding..
Thank you very much for help..
				Results 1 to 9 of 9
	Do these DVDs require decrypting and what are you using to decrypt them before you convert them to MPEG?
	Well I`m not taking video directly from a disc, I have copied all discs to HDD..
	I have never had problems using VOB2MPG directly from DVD discs when the discs were not protected, but if you have to, you can always rip with DVDFab first, then use VOB2MPG, then edit. alternatives to VideoRedo include the Womble products (VCR, Video Wizard) or some of the freebies such as MPG2Cut2. Note - most (all ?) of the freebies only cut on keyframes, which can be 12 - 15 frames apart on DVDs. Read my blog here.
	Although I've never used VideoReDo - "unreliable" is one word I've never seen used along with VideoReDo. There is something going wrong in the process of getting that DVD to the HDD....or it can mean that these are DVD Recorder made discs, crap discs that didn't burn well(memorex, tdk etc etc burned with Roxio or Nero). A good ripping software will probably end the problem. DVDDecrypter is my personal fave....along with DVDFabDecrypter.
	TMPGEnc MPEG Editor 2.0 ... is one I use ... works in WIN XP and in Windows 7 ... also works with DVD-RAM disks ... that I make with my Panasonic DVD Recorders
  How do I burn DVD ready .mpg files as a video DVD?By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 29th Nov 2011, 16:47
  burning 300 mpg video files on DVD?By twister6 in forum Authoring (DVD)Replies: 3Last Post: 2nd Nov 2008, 20:02
  I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVDBy emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
  Trying to burn a mpg video file to DVDBy bhxtyrant in forum Authoring (DVD)Replies: 8Last Post: 11th May 2007, 15:22
  demux DVD Video to MPG!By GangstaRap in forum Authoring (DVD)Replies: 10Last Post: 8th May 2007, 18:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
