I'm searching for software that will allow me to edit and author DVDs. I'm currently using AVS Video Editor.....it works well, but I can't edit the Main Menu Page. Unfortunately, AVS doesn't have any plans on updating the Video Editor. Much as I like it.
I tried using the Womble products, but they're not working well.
What I'm looking for in a software package is : Multiple tracks for video, text and audio, ability to create chapters, effects and transitions and the ability to "edit" the menu page.
I know it sounds like a lot........but, it seems that most of the software that I've been looking at only has a few of these features. And some of them only do EDITING, while others only do AUTHORING. And, a few that I've checked out don't even have any tracks for video, text and audio ! The REALLY good ones are in the Prosumer and Professional category.
garystan
if you want somthin thats easy to use then thats a simple answer... TMPGEnc Authoring Works...if u want a lot of functionality and do it all then prolly...Sony Vegas Pro
If you want to do it properly then you want to use an editor to do your editing, and an authoring tool to do your authoring. All-in-one tools are always a series of compromises, and always have lesser tools than dedicated tools.
I use DVDLab pro, however you could look at DVD Styler for your authoring. It can also encode. Editing should always be done in an editor.Read my blog here.
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 19:43 -
DVD authoring/editing questions from a total n00b
By DesertAvenger in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2009, 12:39 -
Trying to decide on SW: Video editing, DVD Authoring...
By ewingr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 23rd Dec 2008, 13:50 -
New Video Editing/DVD Authoring Software
By rodhudson in forum Newbie / General discussionsReplies: 8Last Post: 17th Oct 2007, 02:47
