    Nov 2003
    Hi,
    I want to encode my DVD's and some movies in other formats to MP4 to play on AppleTV for a wide screen TV. However I am having a problem getting the right aspect ratio to show.
    Basically different movies are giving different results. Some just show in a box (i.e. black on all 4 sides.) and I have to mess about in order to get it to fill the screen from left to right when I watch them.
    What aspect ratio / pixel size should I encode to so all output movies have the same, wide screen aspect ratio.
    Any help would be much appreciated.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    • Video formats: H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats. MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats. Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format
    • Audio formats: HE-AAC (V1), AAC (16 to 320 Kbps), protected AAC (from iTunes Store), MP3 (16 to 320 Kbps), MP3 VBR, Audible (formats 2, 3, and 4), Apple Lossless, AIFF, and WAV; Dolby Digital 5.1 surround sound pass-through
    http://the-gadgeteer.com/2011/07/03/apple-tv-2nd-generation-review/
    Nov 2003
    Cool, thank you.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Handbreak has a preset for AppleTV but it's video dimensions don't match what I posted above. I use Handbreak for my iPod Touch videos.
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    xmedia recode has a bunch of apple presets, tv included.
    Nov 2003
    Great, thanks. I'll try those out well.
