So i have been going through tons of components for my next build and i found a motherboard that has 6 - SATA 6 Gb/s connectors and 2 - 3 Gb/s connectors.
What is the point of having the 2 - 3 Gb/s connections with 6 - 6 Gb/s connections on the same Mobo ?
I thought you could just plug 3 Gb/s HDD's into a 6 Gb/s connections/plugs and they would work, but just at the 3 Gb/s transfer rate ?
Results 1 to 10 of 10
3gb for older hdd and optical drives and 6gb for the newer gb/s hdd,3gb hdd will work on 6gb at 3gb but you won't see any really speed difference between the two unless you got a fast ssd.
That's kind of my point.
If you can plug a 3Gb/s sata HDD into a 6Gb/s sata plug on a motherboard, what is the point of having both 6 Gb/s & 3 Gb/s plugs on the same mobo.
I know the 3 Gb/s hdd wont run any faster. -
The older 3 GB/s chips are cheaper. Typically they're built into the VLSI chipset whereas the 6 GB/s ports may be on a separate controller chip. Licensing is probably cheaper. And there's less possibility of compatibility problems.
I can see that, but with both 6 Gb/s & 3 Gb/s plugs on the same mobo it can't be cheaper.
It just struck me as weird having both on the same mobo. -
i'm not complaining at all, i like the extra sata ports they are adding these days. my last build motherboard has 11 - 6 sata3, 4 sata2 and 1 esata. all used, almost wish for 2 more, but when the time comes an add-in card will do.
Of the motherboards i have looked at, namely Gigabyte, they have 6 - 6 Gb/s connections, 1 has 6 - 6 Gb/s + 2 - 3 Gb/s connections.
Obviously to add those 2 extra 3 Gb/s connections is going to add to the cost.
And even though the 3 Gb/s connections are cheaper, you would think to add 2 different speed connections onto the same board, 6 + 2, would cost more than just making 8 of the same speed connections at 6 Gb/s.
As opposed to having 2 different chipsets/controllers/ what have you....
On the same mobo. -
One thing i did notice is that the Mobo with the 6 + 2 sata jacks, also has an IDE connection.
But i doubt i will ever need one of those for any future builds as i am looking at higher boards for such things as faster and larger amounts of ram, sli, etc.
And i don't know that i will need 16gb of ram, let alone 32gb of ram, but it will be nice to be able to if i want
I am even considering putting in an SSD for my boot drive but but that may be the last thing i install as i don't really need to have it to finish my new build. -
The chipsets that are compatible with the various CPU sockets have controllers which place a limit on the number and type of SATA and eSATA connections that can be placed on the board. All the ones I looked at have a limit of 6 total. Some allowed all 6 to be 6GB/s SATA connections. Others only allowed a combination of 3GB/s and 6GB/s. I can't recall which ones still permit IDE.
If there are more than 6 SATA/eSATA, connections, the extras must come from additional controllers installed somewhere on the motherboard. IDE may be added the same way. I guess it comes down to what controller they choose to add the extra ports not supported by the main chipset.
IDE and 3GB/s controllers would be added just to support legacy drives. The controllers that can provide IDE may not even support 6GB/s SATA.Last edited by usually_quiet; 13th Aug 2011 at 12:16. Reason: clarity
Extracting VOB from DVD, VOB2MPEG jacks up the video
By scottlindner in forum DVD RippingReplies: 13Last Post: 3rd Apr 2012, 13:20 -
RCA Jacks clarification.
By therock003 in forum Newbie / General discussionsReplies: 49Last Post: 23rd May 2009, 00:23 -
rca jacks on media center pc
By Wolhay in forum Newbie / General discussionsReplies: 17Last Post: 15th Mar 2009, 05:33 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47 -
DL (+R) break point
By pheldd in forum MediaReplies: 5Last Post: 10th May 2007, 11:15
