I just started getting this error. Would removing all of the newst beta fix it?
An unhandled exception has occurred in XviD4PSP v5.10.250.0!
Source:
PresentationFramework
Exception:
Cannot create instance of 'MainWindow' defined in assembly 'XviD4PSP, Version=5.10.250.0, Culture=neutral, PublicKeyToken=null'. Exception has been thrown by the target of an invocation. Error in markup file 'XviD4PSP;component/windows/MainWindow.xaml'.
Stack trace:
at System.Windows.Markup.XamlParseException.ThrowExce ption(String message, Exception innerException, Int32 lineNumber, Int32 linePosition, Uri baseUri, XamlObjectIds currentXamlObjectIds, XamlObjectIds contextXamlObjectIds, Type objectType)
at System.Windows.Markup.XamlParseException.ThrowExce ption(ParserContext parserContext, Int32 lineNumber, Int32 linePosition, String message, Exception innerException)
at System.Windows.Markup.BamlRecordReader.ThrowExcept ionWithLine(String message, Exception innerException)
at System.Windows.Markup.BamlRecordReader.CreateInsta nceFromType(Type type, Int16 typeId, Boolean throwOnFail)
at System.Windows.Markup.BamlRecordReader.GetElementA ndFlags(BamlElementStartRecord bamlElementStartRecord, Object& element, ReaderFlags& flags, Type& delayCreatedType, Int16& delayCreatedTypeId)
at System.Windows.Markup.BamlRecordReader.BaseReadEle mentStartRecord(BamlElementStartRecord bamlElementRecord)
at System.Windows.Markup.BamlRecordReader.ReadElement StartRecord(BamlElementStartRecord bamlElementRecord)
at System.Windows.Markup.BamlRecordReader.ReadRecord( BamlRecord bamlRecord)
at System.Windows.Markup.BamlRecordReader.Read(Boolea n singleRecord)
at System.Windows.Markup.TreeBuilderBamlTranslator.Pa rseFragment()
at System.Windows.Markup.TreeBuilder.Parse()
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at System.Windows.Application.LoadBamlStreamWithSyncI nfo(Stream stream, ParserContext pc)
at System.Windows.Application.LoadComponent(Uri resourceLocator, Boolean bSkipJournaledProperties)
at System.Windows.Application.DoStartup()
at System.Windows.Application.<.ctor>b__0(Object unused)
at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Boolean isSingleParameter)
at System.Windows.Threading.ExceptionWrapper.TryCatch When(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
Inner Exception:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TypeInitializationException: The type initializer for 'System.Windows.Window' threw an exception. ---> System.TypeInitializationException: The type initializer for 'System.Windows.FrameworkElement' threw an exception. ---> System.MissingMethodException: Method not found: 'Boolean System.Double.IsPositiveInfinity(Double)'.
at System.Windows.FrameworkElement.IsWidthHeightValid (Object value)
at System.Windows.DependencyProperty.ValidateDefaultV alueCommon(Object defaultValue, Type propertyType, String propertyName, ValidateValueCallback validateValueCallback, Boolean checkThreadAffinity)
at System.Windows.DependencyProperty.ValidateMetadata DefaultValue(PropertyMetadata defaultMetadata, Type propertyType, String propertyName, ValidateValueCallback validateValueCallback)
at System.Windows.DependencyProperty.RegisterCommon(S tring name, Type propertyType, Type ownerType, PropertyMetadata defaultMetadata, ValidateValueCallback validateValueCallback)
at System.Windows.DependencyProperty.Register(String name, Type propertyType, Type ownerType, PropertyMetadata typeMetadata, ValidateValueCallback validateValueCallback)
at System.Windows.FrameworkElement..cctor()
--- End of inner exception stack trace ---
at System.Windows.Window..cctor()
at System.Windows.Window..ctor()
at XviD4PSP.MainWindow..ctor() in C:\XviD4PSP\windows\MainWindow.xaml.cs:line 108
at System.RuntimeTypeHandle.CreateInstance(RuntimeTyp e type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)
at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
Results 1 to 1 of 1
xvid4psp crashes if denoise is enabled
By codemaster in forum Video ConversionReplies: 1Last Post: 30th Apr 2012, 17:40 -
Xvid4psp crashes
By skorpinok in forum Video ConversionReplies: 1Last Post: 9th Jul 2011, 14:59 -
XviD4PSP 6.03.922 Beta crashes
By efini93 in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2011, 09:43 -
Xvid4psp does not work on Windows 7 64 Bit version
By pectin232 in forum Video ConversionReplies: 0Last Post: 28th Nov 2010, 19:41 -
SVC2DVD 2.5 crashes when installed in Vista Ultimate
By paparay in forum SVCD2DVD & VOB2MPGReplies: 26Last Post: 4th Oct 2007, 05:04
