I downloaded part 5 of a movie because I want a scene that I know is at the end and don't want to download the earlier parts. But when extracting the RAR I got an error message that it was broken, nevertheless, it extracted an AVI file that appears to be of the correct size as my download. A different RAR program said that I needed the earlier parts in order to extract it.
Anyway, no player will play the AVI file. I ran it through DivFix++ and DivXRepair as well as Virtualdub, VirtualdubMod and Avidemux, and none will fix it or play it. DivFix++ says "this is not an AVI file."
Is there any way to make this playable without downloading parts 1-4? I have noticed in the past that if I download a partial AVI, if it's part 1 it can be made playable, but later parts can't in the absence of part 1. But I'm hoping there's a way around this. Thanks for your suggestions.
What programs did you use for the extraction? In the past I used to always use Winrar but now have switched to Alzip as it does a better job extracting files that may come up as broken or CRC errors. Hope that helps...
rips don't produce playable video?
By idiotbox37 in forum Blu-ray RippingReplies: 1Last Post: 27th Jun 2011, 23:22 -
need help with HDConvertToX to make avi that is 1hr+ playable in DVD
By lett303 in forum Video ConversionReplies: 0Last Post: 6th Oct 2010, 14:30 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
Want to make a video split in 3 parts into 1 part...
By Keier in forum EditingReplies: 1Last Post: 11th Sep 2009, 02:37 -
WMV file to AVI playable on DVD player (motion is uneven when I try)
By lizzy1e in forum Newbie / General discussionsReplies: 0Last Post: 29th Jun 2007, 15:13
