I received some of these "Made On Demand" discs for a birthday present. They skip like mad on at least 4 players so I wanted to see what these really are. LG 22 and 55 burners don't even see the discs when inserted. My Sony/Optiarc 7200 sees them no problem but analysis with several ripper programs shows bad sector/burns galore. Discs are Optiarc +R double layer set for DVD ROM. You also can't return the discs for new ones as they ARE just burns from the manufacturer (not pressed discs). I've been checking several forums and this seems to be common now...bad burns from high speed burners of rare TV series and movies from big outfits like WB, MGM, HB, etc. Very frustrating to wait all this time to get these (expensive) discs only to have them be unplayable. Just a warning to anyone who might be thinking of purchasing this junk...![]()
Verbatim + DL ... anything else is rubbish ... which appears to be what there using.
You'll have your work cut out recovering the data. -
I had not heard of this service before, but in reading about "What to do if your DVD won't play," there should be customer service number that you can call if the DVD doesn't play. Prices seem pretty high for this service.
Amazon says unreturnable once bought. Manufacturer says I shouldn't have them at all as they were supposed to be USA only. Guess I'm stuck with them. Yeah, having the manufacturer use junk instead of good discs was really a surprise. You'd think they'd know by now...
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
It'll cost you time for the burns and cost for the blanks, but you could put the discs in the reader that can see them correctly, then rip the contents (as files, NOT as ISO) to a HD folder using ISOBuster, etc. Then use ImgBurn to "Build" a new, GOOD discimage and burn onto Verbatims...
Worth it? I don't know. How many have you already bought?
Keep getting bad DVD burns after OS reinstall
By brassplyer in forum ComputerReplies: 18Last Post: 20th Sep 2009, 02:12 -
Toshiba RD-XS35 producing a relatively high amount of bad/weird burns
By Bix in forum DVD & Blu-ray RecordersReplies: 14Last Post: 23rd Sep 2008, 12:25 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 14:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 04:23 -
Are Verbatim's 'Made in Taiwan' discs...
By dvdashot in forum MediaReplies: 2Last Post: 8th Aug 2007, 14:55
