Hey all,
I'm wondering if anyone has successfully used the Thermaltake BlacX Duet Dual hard disk enclosure to connect TWO SATA300 hard drives to a computer over the eSATA cable. I thought I'd be able to do this with my PC (an ASUS M4A88TD-V EVO/USB3), but, when using eSATA, Windows (XP Pro, 32-bit SP3) can't see either HDD in the BlacX while both are on simultaneously. One drive alone works fine, however.
I went into PC BIOS, and the BIOS detects and shows both HDDs on the eSATA connection. I figured this meant I was okay. But when Windows comes up, then neither drive are visible on eSATA. I also made sure that my AHCI driver for WinXP is current. AFAIK, my SATA controller H/W is "port multiplier" capable.
Has anyone here successfully gotten the Thermaltake BlacX Duet to connect two HDDs to a PC over eSATA?
I have one. Works fine on my windows 7 PC with an add on eSATA port multiplier card.
Steve
Soprano Thermaltake loud fans problem
By SE14man in forum Newbie / General discussionsReplies: 5Last Post: 27th Aug 2011, 23:22 -
Connecting more HDDs to the Computer Uses More Power?
By imdaman in forum ComputerReplies: 12Last Post: 13th Dec 2010, 00:06 -
Can I use an Avermedia Duet with Verizon FIOS to access the clear-QAM?
By Chuck584 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2010, 14:46 -
how to connect esata port on MB to external esata HDD
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Dec 2007, 13:45 -
Firewire VS. eSATA/eSATA II - which would you rather have?
By Cyrax9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th May 2007, 10:59
