I ask I can connect all Types of hard drives my Blue Ray Phillips bdp3100 If there is limit what it is and if you can Complex explanation
Thank you all
	rtfm --
	It seems to have a USB 2.0 input, so possibly. But the hard drive would likely have to be formatted in FAT32, the same as a USB thumb drive, where most hard drives use NTFS formatting.
 You can use a freeware program like SwissKnife for formatting the hard drive. http://download.cnet.com/CompuApps-SwissKnife-V3/3000-2248_4-10070864.html This may not work with very large hard drives, but you can probably partition them to smaller sizes if needed. There is also a 4GB file size restriction with FAT32, so your files would have to be sized to fit.
  connecting external hard drive to blu ray player then accessing data off itBy julie_152 in forum DVD & Blu-ray PlayersReplies: 36Last Post: 24th Sep 2012, 08:44
  Blu-Ray Player that plays .avi (and other) with external hard drive?By RushMaster in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Dec 2011, 12:51
  Playing my external hard drive from LG blu ray???By Shadowx22 in forum Newbie / General discussionsReplies: 9Last Post: 17th Oct 2011, 07:21
  Help with using external hard drive with Insignia Blu-Ray Player NS-WBRDVD!By charr83 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Jan 2010, 12:50
  wd tv blu ray to hard driveBy bob666black in forum Blu-ray RippingReplies: 7Last Post: 25th Apr 2009, 08:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
