Closed Thread
    Aug 2009
    Germany
    Hello!
    Since I found no suitable category I write here once the improvements. They refer to 0.9.4.1:
    1st I find no way to take back the last steps. For example, to restore accidentally deleted a picture.
    2nd It would be nice if the Aanzeigedauer and the transitional period may also be entered in seconds.
    3rd In summary, all possibilities to work directly sein.Ich thinking, for example, the subtitle, the slides.
    4th Very Long subtitles are not wrapped but start somewhere and end up behind the front image.
    5th Subtitle effects on Englich and not fully visible.
    6th To edit images, a program designed to be. This is not possible because the selection is accepted.
    7th The images and the music should be sorted with the mouse. this does not exist.
    8th It should start right after the installation is already in German, the change is too complicated for many.
    Then one more important point:
    9th There are apparently no competent German forum. A major problem for many non-English speaking (even for me)
    Excuse the bad English but I use the Google translator.
    Sincerely, R. Lehmeier
    Jan 2007
    Republic of Texas
    Well, that's about as clear as mud.
    Mein Luftkissenfahrzeug ist von den Aalen voll.
    Aug 2006
    Version 0.9.4.1 of what? You forgot to include the name of the software.
