  1. I'm using FFmpeg from live encoding and I want to clarify if there's any way to change the encoding rates while it's in-action (Already encoding).
    So... Is it possible?
    Oct 2005
    666th portal
    no you can't change bitrate in the middle of an encode, and if you did manage to do it, the video would become unplayable. you might be able to use vbr next time or cq mode and the encoder will use whatever bitrate it needs.
  3. I agree that ffmpeg can't do it. (Open Broadcast Encoder see: http://forum.doom9.org/showthread.php?p=1478432 might be able to support it)
    Why that? Please explain further, afaik this is possible when using libx264 or libav directly and it should not render the video unplayable.
    Oct 2005
    666th portal
    maybe if it were a transport stream where the needed info to play it is always there, but an h264 program stream has a moov atom and mdat atoms that will be incorrect. i could be wrong but that's my understanding.
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Difficult to do when live but relatively easy for non-real time post where you have a recorded frame history. Expensive realtime hardware encoders have several frames of memory allowing real time adaptive motion compensation. These are used for live sports uplink to limited bandwidth sat transponders.
    If you are just recording, do it high bit rate CBR.
    http://www.kiva.org/about
  6. moov atom and mdat atoms,... these are for the mp4 container,...
    + http://x264dev.multimedia.cx/archives/286
    + seems like GEFORCEXTREME over at doom9 managed to modify VLC to adjust bitrate on the fly
    -> so I really think it is possible
    Cu Selur
