New here, so if its been covered I apologize, I could not find anything in my search.
So I have a few files from a friend on a portable HD, they are all MPEG-2 TS 1080 files, I would like to convert them to mkv, 720p & 1080p. I have Xilisoft Video Converter Ultimate, however after the encode the audio is only in one channel at times.
I tried a few different audio options, mp3, AC3, and tried both "Stereo" and "6 channel" outputs but both are the same.
Anyone have any suggestions, maybe for this program, or another one that has a good video/audio output?
there are lots of great free transcoders to try - mediacoder, handbrake, xmediarecode, multiavchd, etc.
Thanks. The xmediarecode seems to work and give the correct audio output, but the video is all pixelated.
Its strange, when playing the original it sounds fine, stereo audio from both front speakers. But after the conversion the audio is separated, like half in channel 1 and half in channel 2. -
I like Xilisoft, but you have to make sure you get everything right and even then it burps on itself once in awhile. Its attempt to make things too easy have made it too hard, sometimes.
If Xilisoft is giving you a good video stream at 720p, then here's what I would do:
1 - Convert the 1080p to a 720p .mkv with Xilisoft, ignoring the audio track settings completely cuz we're gonna throw it away in the end.
2 - Demux the 1080p MPEG2-TS with tsMuxer
3 - Demux the 720p .mkv from Xilisoft with tsMuxer
You should have a 720p video stream, a 1080p video stream, the original audio stream and the audio stream that you got from Xilisoft.
4 - Delete the Xilisoft audio track.
5 - Remux the 720p video stream with the remaining (original) audio track with MKVmerge
6 - Remux the 1080p video stream with the same audio track with MKVmerge
Should save you some encoding time for the 1080p to 1080p and you'll have no quality loss. -
Thanks smitbret, that seems to work for the most part. I was able to encode the vid to 1280x720, strip the audio and remux it with the good audio.
Its still in MPEG2 .ts format, but my WD Media player will play it....
Still going to keep trying to find a fix so I can encode to a mkv tho... Guess Im just stubborn...
Here are the MediaInfo files:
Original: 1920x1080 MPEG2 TS
Here is the encoded 720p:Code:General ID : 1 (0x1) Format : MPEG-TS Format/Info : Audio Coding 3 File size : 13.6 GiB Duration : 1h 47mn Overall bit rate : 18.1 Mbps Video ID : 626 (0x272) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@High Format settings, BVOP : Yes Format settings, Matrix : Default Codec ID : 2 Duration : 1h 47mn Bit rate mode : Variable Bit rate : 16.9 Mbps Nominal bit rate : 80.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.271 Stream size : 12.6 GiB (93%) Audio ID : 625 (0x271) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 1h 47mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 6ms Stream size : 295 MiB (2%) Language : English
Code:General ID : 1 (0x1) Format : MPEG-TS Format/Info : Advanced Video Codec File size : 7.93 GiB Duration : 1h 47mn Overall bit rate : 10.6 Mbps Maximum Overall bit rate : 35.5 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L1.3 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : 27 Duration : 1h 47mn Bit rate mode : Variable Bit rate : 9 679 Kbps Maximum bit rate : 40.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.350 Stream size : 7.25 GiB (91%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Codec ID : 129 Duration : 1h 47mn Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 6ms Stream size : 295 MiB (4%) Language : English
Xilisoft video converter help
By paul278 in forum Video ConversionReplies: 3Last Post: 18th Sep 2011, 05:12 -
By Vman94 in forum Video ConversionReplies: 0Last Post: 12th Jul 2011, 11:35 -
Xilisoft Video converter from mvk to dvd - audio problem
By sychern in forum AudioReplies: 4Last Post: 10th Oct 2008, 02:57 -
WMV to AVI using Xilisoft Mac Video Converter
By BassJunkie in forum MacReplies: 11Last Post: 30th Jul 2008, 02:31 -
By burgkev in forum Video ConversionReplies: 1Last Post: 16th Mar 2008, 16:32
