http://www.dropshots.com/sneezer#date/2011-08-11/03:15:15
Is there a way to fix this, and more importantly, prevent this from happening again? I used a lossless codec from MSU, and i made this video with camstudio. Anyway, here is the resulting file. Can it be fixed? Can it also be prevented? It's supposed to be a video of a woman's shoe, but as you can see, it's all slanted. Please advise...
	Could be the div by 2 issue ... what ever you recorded should have a resolution of both height and width being divided by 2 ... anything else may produce slanted video ... should be able to load the video into virtualdub, video set to full processing then apply video > filter > resize ... make sure height and width are dividable by 2 ... video > compression ... generally xvid or other.
 If audio is included set to full processing then compression.
 Once done go to file > save as ... choose location to save new file and name it ... and let virtualdub run the task.
 Now the new file should play as expected.
	Thanks Bjs!! That did the trick. Note to self: Make sure height and width are divisible by 2.
  Which codec/container makes lossless video editing possible?By ilimitus in forum EditingReplies: 14Last Post: 29th Jan 2011, 14:06
  after effects cs3 lossless video codec missingBy thecrock in forum Newbie / General discussionsReplies: 0Last Post: 5th Apr 2010, 09:42
  Need a lossless codec that works in Windows 7/VistaBy LSchafroth in forum EditingReplies: 13Last Post: 25th Nov 2009, 11:12
  lossless video-codec good for editing in PremiereBy phpmysql348 in forum Video ConversionReplies: 4Last Post: 11th Jun 2008, 22:41
  Lossless Audio Codec Comparison '07By Tab in forum AudioReplies: 8Last Post: 3rd Jul 2007, 02:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
