  1. Member koberulz's Avatar
    Oct 2006
    Australia
    I want to rip a sequence from a Blu-Ray disc, and then use that with some other footage I have to create a Blu-Ray of my own in Adobe Encore.
    What's the best way to do this?
    Probably with dvdfab, http://www.dvdfab.com/blu-ray-ripper.htm . You can rip, edit and output to m2ts (if encore supports it then) directly.
    If you want free tools it gets harder, rip the entire blu-ray with dvdfab hd decrypter, edit the m2ts with tsmuxer(no preview).
  3. Member koberulz's Avatar
    Oct 2006
    Australia
    DVDFab only displays one of the clips I want to rip out when in Blu-Ray Ripper mode. If I set it to Blu-Ray copy, then select 'Main Movie', it displays a couple more but is still missing two.
