Hello,
I'm sorry if this is not the right section for this kind of problems.
I downloaded two .mkv files in order to see them in my BluRay player (LG BD550) via Usb HDD. Both files already have subtitles incorporated (english subtitles) and I can see them with any kind of problems. Now, the idea is to add aditional subtitles to the films. After googling a little bit, I read that mkvmerge GUI allows to add aditional srt files to the container. I downloaded the program, add the desired srt files, but then the movies don't start in my bluray player... I press play and nothing happens...
It's obvious that the problem is in the muxing process, because the initial files work and then they stop working.. Does anybody know what's the problem here? Is there any change in the video track that makes the mkv stop working? Thanks in advance.
disable header compression or use an older version of mkvtoolnix (4.0 or older)
poisondeathray,
OK, i will try both of the suggestions
Thanks for your reply. -
This is how I disable header compression?
extra options -> compression -> none -
Yep, you can select it manually for each track or under File->Options choose Disable header removal compression for audio and a video tracks default and will always be disabled.
Problem splitting mkv files
By Sennaista in forum Video ConversionReplies: 8Last Post: 5th Jul 2012, 21:57 -
Stripping sections of MKV files to seperate smaller MKV files
By spudz72 in forum EditingReplies: 6Last Post: 29th Jul 2010, 01:53 -
a problem opening MKV or MP4 files
By gis4ever in forum Video ConversionReplies: 10Last Post: 7th Jul 2010, 12:39 -
problem playing mkv hd files in my pc
By gotenks_fp in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2010, 15:46 -
problem in demuxing mkv files
By noskid21 in forum EditingReplies: 2Last Post: 13th Aug 2007, 12:12
