http://www.amazon.com/gp/product/B001CN9GEA?tag=streamingme01-20
I was looking for a capture card like that to record hdmi xbox 360 gameplay. I could use that and stick it in my PC and it will be fine but I want one for my laptop, or something like this that would work for a laptop so I can travel with it. I don't no if there is a box or something that would act like the product in the link above but if there is or something similar please post below.
they make a usb(3.0) version of that called the shuttle, but it's very picky about what usb(3.0) ports it works in. no laptops make the grade that i know of.
Why not go with a hauppauge hd pvr? Why does it have to be hdmi? Component will still look very good. THough the hd pvr is limited to 1080i. I don't know if that would be a deal breaker for you or not. But it is a proven and well recommended capture device. I have one that does what I want it to. And yes you can do 5.1 dolby digital with fiber optic.
- hd pvr is usb fyi.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
ok yes that will work but then the porblem that im having now is going from the RGB visaul cords to vga, dvi, or hdmi so I can see what im playing on my monitor.
Too bad you don't have component input on the monitor. The hd pvr has component passthrough.
THere are rca plugs on the component cable for the 360. There are reports that it can output both simultaneously. I have not done that myself so its only speculation on my part. I don't know if thats possible or not.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
ok i found a solution to all who want to no. I'm going to get the HD PVR and a xbox 360 RGB cord. hook that up and then the output will be red & white audio cables going to a Y plug that PC speakers can connect to giving me sound! The visual was tricky but im going to get a hdmi to 3 RCA conversion cable which will plug into my awasome monitor. Now I can watch what I record! Thanks for showing me the HD DVR and your welcome to those who found this usefull!
That won't work. Those cables are for specific devices that supply component video on what looks like an HDMI port -- but's not an HDMI port. It takes active circuitry to convert component to HDMI or vice versa. HDMI/component scan converters start around US$50. For example:
http://www.amazon.com/Cables-Unlimited-Component-Video-AUD-2360/dp/B0032HOL4E
Note that device doesn't have analog audio support.Last edited by jagabo; 10th Aug 2011 at 22:30.
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Trying to find the best way to record Xbox 360 gameplay
By Zaz in forum Capturing and VCRReplies: 2Last Post: 2nd Dec 2009, 08:12 -
The BEST Way To Play & Record Xbox 360 Through Your PC?
By njosnavelin78 in forum Capturing and VCRReplies: 142Last Post: 25th Dec 2008, 14:43 -
Record XBOX 360 to Laptop using a VGA cord
By Renzeko in forum Capturing and VCRReplies: 1Last Post: 18th Jul 2007, 21:35 -
Would the HAVA Pro HD be my best choice to record from my Xbox 360?
By Mysteriouskk in forum Capturing and VCRReplies: 1Last Post: 17th May 2007, 03:55
