i recently received a new computer as a gift from a family member for graduation and turns out its a slim and doesnt have a firewire port... i bought two firewire cards both of which didnt fit. i bought a 1394 cardbus adapter because i was told it would work, turns out computer didnt have a cardbus slot. im thinking about an express card which i believe is a little slimmer? if that doesnt work then idk, maybe an external capture card like the pinnacle ultimate or plus? would the external capture card cause me to lose video quality? im desperate for answers cause i have to finish a full length video by september... please help VH members
Results 1 to 10 of 10
i have the emachine el 1352 slim. http://www.emachines.com/products/products.html?prod=EL1352-03
Yep, you need an external solution if you don't fit any PCI/PCI-Express, cardbus, etc. Like a pinnacle moviebox hd should do it , http://pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+Fami...version+14.htm . It can capture/record from dv and also output as dv to your camcorder. You just need a free USB2 connection.
Why do you need a 1394 port? For a DV camcorder? An ADVC-100 or similar?
Why didn't the 1394 cards fit? Cardbus and Express Card are usually used in laptops (desktops don't have slots for them). A slim desktop would usually use a half height PCI or PCIe card. For example:
http://www.amazon.com/StarTech-com-Profile-1394a-FireWire-Adapter/dp/B0002XMZOO/
These aren't 1394 cards but it shows a half height card with a half height bracket and a full height bracket:
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01951393Last edited by jagabo; 10th Aug 2011 at 08:27.
the box has 2 open slots.
PCI Slots (Available/Total)(1/1) PCI Express x1
(1/1) PCI Express x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16815150151--
Or cheaper if you have a PCI slot:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158020
Ah, NewEgg shows the computer only has PCIe:
http://www.newegg.com/Product/Product.aspx?Item=N82E16883114085 -
No, you won´t. The Pinnacle card will transfer your DV video to your HDD and the resulting .avi files will be editable with the editors you mention if you don´t like Pinnacle´s own. You also have the option to convert your DV to .mpg on the fly within the capture section of Studio and finally, the external box will enable you to capture also analog sources (composite & S-Video), converting them to DV AVI or mpg.
Wouldn't something like this work?
http://cgi.ebay.com/half-height-PCI-Express-Card-2-Firewire-ports-w-cable-/40023510421...item5d2fdf07dbLenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W.
Firewire device to computer with no Firewire
By dbuser2 in forum ComputerReplies: 11Last Post: 24th Sep 2010, 20:32 -
Urgent computer help
By Seasonal in forum ComputerReplies: 24Last Post: 23rd Jul 2008, 02:49 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19 -
Tranfer DV from SONY DCR-PC7 via Firewire to computer
By riverdaleDV in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 11:10 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 09:20
