Is there a free program that will allow me to stretch/shrink the audio and then preview it with the video to see if its in sync? Programs like virtualdub and avidemux only have a time delay option, I think, and not the stretch/shrink that I need to fix the audio. Alternately, what's the best way to fix audio sync problems that aren't a simple time delay? I've read a dozen posts on here and around Google and my brains gonna explode...
Virtualdub also has an option to change the video duration to match that of the audio.
In all actuality I believe you need to determine the cause/type of audio sync issue you are having, there could be a myriad of reasons cause the audio and video to loose sync. Hell, I've seen what appeared to be a badly fragmented drive cause sync issue. There should be a guide in the forums that describes how to identify and correct audio/video sync issues.
Is this a file that was downloaded, or it file that was captured from like vhs or DBS?
Is the file converted from one format to another, i.e NTSC to PAL?
Give us some details about the problem and perhaps we can give you a option to best address your specific scenario. -
Virtualdubmod has an audio stretch freature to match the video. Check the help contents/audio filters.
You can test the results in the time line.
Free program to join vob files with dts audio
By shans in forum Newbie / General discussionsReplies: 3Last Post: 11th Apr 2013, 07:50 -
Free software to stretch or compress video
By smigh in forum EditingReplies: 1Last Post: 17th Jul 2011, 21:27 -
Shrink (Reversed Stretch) 16x9 to 4x3 without black borders
By Paker in forum Video ConversionReplies: 4Last Post: 14th Sep 2010, 12:09 -
How to stretch/shrink subtitles
By las7h0p3 in forum SubtitleReplies: 0Last Post: 8th Oct 2008, 14:32 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 05:14
