i've been searching many stores for a firewire-to-usb plug or hub or whatever they're called. bestbuy, bjs, staples, officemax, even looked on amazon, noone carries such a thing. they say it doesn't exist.
so i want to connect my sony trv22 cam to my netbook, it only has two usb2 ports, no fw, so i'm looking for a fw2usb if they exist...so, do they make fw2usb something, where i can pick one up, or am i wishing, thanks for any leads.
http://www.kiva.org/about -
If your netbook has a pcmcia slot you could use something like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124014&nm_mc=OTC-Froogle&cm_m...yba-_-15124014 -
I have the same problem with my new laptop. Called tech support and they said NOPE! (for my machine) I almost can't wait for my video camera to die, just so I won't have this problem, but I'm so used to my video camera's function's and features. Uncompressed... whah!!! I keep my 8 yr old desktop around just to upload video.
Not exactly a hub or adapter but can do firewire to USB2 and ALSO allows you to capture from analog sources (to DV AVI, AVI or MPG)
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Home+Video/Studio+...version+14.htm
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 12:28 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 21:01 -
Can I capture with USB 2.0 or does it have to be Firewire?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 7th Feb 2009, 13:19 -
USB or firewire
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2009, 21:42 -
Firewire to USB
By DNCR556 in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2007, 10:45
