Here's what I have: Dish network with HD receivers.
Here's what I want to do: Capture video onto my PC (Laptop)
in a format that I could import into a video editing software (eg: Sony Vegas).
I'd like to be able to start and stop recording when I want to.
(Optionally: I'd also like to be able to receive over the air HD if possible with the same device.)
Question: What device and manufacturer can give me this?
Thanks,
Ray
Can't think of any that does both.
Hauppauge HD-PVR caps HD analog component and converts to h.264 which is somewhat difficult to edit depending on your laptop spec. Note that many set top tuners won't output HDMI and analog component at the same time.
There are many USB HD tuner sticks that cap ATSC.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Over the air digital TV is ATSC (MPeg2 codec) in USA. The channels you tune can be SD or HD as broadcast. These tuners just separate the tuned channel and capture the broadcast stream to an MTS file without recode.
http://en.wikipedia.org/wiki/ATSC_%28standards%29
http://en.wikipedia.org/wiki/Transport_stream
Typical USB ATSC tuner "stick"
http://www.google.com/products/catalog?hl=en&cp=11&gs_id=y&xhr=t&q=hauppauge+tv+tuner&...ed=0CE8Q8wIwBA
http://www.hauppauge.com/site/products/data_hvr950q.htmlLast edited by edDV; 9th Aug 2011 at 17:55.
Here are more examples of external ATSC tuners with a USB interface.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100048
http://www.newegg.com/Product/Product.aspx?Item=N82E16815116029
This is an external ATSC tuner with a different interface. It plugs into your home network.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815345007 -
But be assured none of these off-air tuners will cap from your Dish service other than some will cap SD from composite/S-Video.
We are talking two devices here if you want to cap HD from Dish..Recommends: Kiva.org - Loans that change lives.
Recording HD to a PC
By goose756 in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2010, 12:17 -
Video recording
By jmostert99 in forum Newbie / General discussionsReplies: 1Last Post: 6th Jun 2010, 05:41 -
Recording a better copy of an old recording.
By cyber-junkie in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 15:48 -
Recording HD TV
By Johnny 44 in forum DVB / IPTVReplies: 2Last Post: 28th Jun 2009, 01:09 -
recording tv programs
By kasfig in forum Newbie / General discussionsReplies: 20Last Post: 23rd May 2007, 11:40
