Hello,
One can play LPCM 24bits 96Khz audio files in a standard DVD player using LPLEX Very cleverly, it first muxes the audio files (no conversion to AC3) with blank video in mpeg format and second authors a standard DVD
http://audioplex.sourceforge.net/
But at this time LPLEX is in beta stage, and there is a set of files it will convert to mpeg but will freeze in the DVD authoring phase (no error messages, etc).
Is there an easy way to author a very simple DVD (no menus, etc) from a few mpegs and not converting the audio files to AC3 or the like?
Thanks for your help,
I used TMPGEnc Plus and TDA to make mine....not free but cheap(at the time when I bought them).
I'm sure I could do the same with freeware....I just never tried. I'll have to think about that today and get back to you.
Rip DVD with DTS under LPCM
By ddtof in forum DVD RippingReplies: 8Last Post: 29th May 2012, 07:44 -
LPCM 1.0 - is it legal for DVD?
By Alex_ander in forum Authoring (DVD)Replies: 4Last Post: 29th Sep 2011, 03:09 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 10:15 -
How to replace LPCM by AC3 before shrinking a DVD
By cd090580 in forum User guidesReplies: 30Last Post: 24th Dec 2009, 21:47 -
program to shrink dvd and convert lpcm to ac3 all at once
By KakarotX in forum DVD RippingReplies: 6Last Post: 9th Jun 2009, 14:03
