Hi, What would be the best MKV to AVI=divx/xvid. I need to convert 2 files to be able to play them on my philips dvp 5990. Every mkv file i have come accross i have had no noproblems converting them from mkv to avi to play on my divx dvd player.
I have All to Avi, WinAvi, Xvid4psp, and another one that i cant seem to remember the name right now, at work right now. None of them are working on these 2 mkv files, so was wondering what other ones are out there that would work. Also these 2 mkv files have subtitles in them, and would be great to be able to convert to avi and have the subtitles hard coded onto them, audio is jap so realy need them lol.
Anyway, thanks for any and all help.
Results 1 to 10 of 10
What do you mean by "None of them are working on these 2 mkv files"? What is the problem? Do the MKV files player properly?
I would probably use VirtualDub. You'll need to download the DirectShow or MKV source plugin too. -
Ok so the other one I use is called avidemux. None of them will convert it from mkv to avi. Both the files play fine on media player classic and on windows media player. The conversion will start on avidemux and about 10-20 sec in, it will say that an error occured and that it will now close. That happens with one of the files. The other one will get converted to about 70-75% and then says and error occured and shuts down.
All other mkv files have worked either on, avidemux, alltoavi, winavi, or Xvid4psp. These 2 mkv files don't work on neither of the 4 that I have in converting them from mkv to avi. -
It could be that those two Matroska files were created with a 4.x version of MkvMerge and have header compression on by default. It may be worthwhile to use MkvExtract and re-merge with MkvMerge compression set to off to see if that solves the problem.
The thing is that i have ran into this before. I started out with WinAvi. Then when some files wouldn't work I looked for another one and came across, AlltoAvi. And then when I would come across a file that also wouldn't work on either one i would look for another one, and came across, Avidemux, and then finaly got to xvid4psp.
So you see what I mean. If the file won't convert on one I try another one. But now again, I came across these 2 files that won't work on either of the 4 that I have so now looking for another one that it would work on.
I will give it a shot with VirtualDub and MkvExtract. But if anyone else has any more suggestions that would be great. -
ok cool thanks jagabo.
locotus, have you used any of the ones you mentioned? cus i need one that would convert the 2 mkv files into avi=divx/xvid files that can also attached the subs as harcoded subs. -
Yes, at least the one that I've used, megui and vidcoder should manege the subs.
But you must configure then properly.
Vidcoder is a gui for Handbrake and it dropped support
for XviD or DivX some time ago.
In case that nothing works as you wish, perhaps
doing a mkv to mkv could solve your problem, so nobody
could guess what the is the problem of your files. -
I've had good luck with Quick AVI Creator
It actually does a good job in one pass mode if you give it some bit rate to work with.
Out of the box it only has xvid 2 pass mode. Add these lines to the xvid.presets file
if you want a one pass mode. Note: leave a blank line after the [Exact File Size] settings.
[One Pass Mode]
xvid_encraw.exe -i "$video_input" -bitrate $video_bitrate -progress 1000 -avi "$video_output"
Also note that since it encodes HD avi you have to size down your video if the .mkv is HD res.
It won't do it automatically for you.
Before it starts it pops up the .avs script. Just add
BilinearResize(720,480)
edit: the resize works in most cases but if the preview looks like the aspect ratio is messed up you may want to load the .mkv into FitCD to do it right.Last edited by MilesAhead; 9th Aug 2011 at 18:05.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Blueray player with mkv, xvid, divx, avi, etc... support. Advice please!
By szabo_77 in forum DVD & Blu-ray PlayersReplies: 34Last Post: 10th Feb 2016, 12:54 -
Having trouble importing avi's (divx/xvid) and mkv's into Vegas 10
By mr-scarface in forum Video ConversionReplies: 11Last Post: 17th Jan 2012, 11:11 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 14:18 -
My Conversion Dilemma for PS3 Xvid -> DivX and MKV -> AVI
By Alterego in forum Video ConversionReplies: 0Last Post: 30th Mar 2008, 04:10 -
Video not working after x264(MKV) to Divx/Xvid(AVI) conversion using TVC
By CthulhuSaves in forum Video ConversionReplies: 7Last Post: 4th Jan 2008, 00:12
