Skipping from chapter to chapter seems impossible in Apple's DVD Player if it comes to DVD-menus made with Toast.
Is there a workaround?
Results 1 to 13 of 13
Can you try a DVD you made with Toast on Windows and see what it does? It might at least let you figure out if the problem is with Toast or with Apple's DVD player. VLC isn't very good on OS X (it is releases behind Windows and Linux in the code base and often has horrible bugs that have long been fixed in those 2 platforms) so the fact that it isn't working means nothing. Toast is made by Roxio and they make truly horrible Windows software so it may be a Toast issue for all I know. If you can get access to a Windows PC it's OK to test with VLC on Windows.
Going from chapter to chapter, using the |<< and >>| buttons in Apple DVD Player, work fine for me with a DVD converted, authored and chaptered by Toast (v11.0.3).
Not sure how your DVD is different. -
@ Case:
I also tried the |<< and >>| buttons in Apple DVD Player.
The difference between me and you is: your DVD has a main feature. My DVD's haven't, they contain short musical video's. Each video is an individual MPEG-2. It's impossible to skip from one MPEG-2/musical video to another. I can only skip within each MPEG-2/musical video. -
This sounds normal to me: on most DVD software and hardware players, the track skip buttons skip between chapters within a title (not from title to title). Titles are normally authored to navigate via the top level menu (thumbnails). This typically holds true of commercial DVDs as well. But the function is somewhat dependent on the design of the player: some of them DO interpret rapid sequential presses of the skip button as a request to jump thru titles instead of chapters.
There are workarounds. You could re-author the DVDs without chapter marks within each clip: including chapters is usually counterproductive when making compilation DVDs of multiple short clips (under 5 mins @), because of the very problem you're experiencing. Chapter skip navigation will almost always plod along chapter by chapter, working its way piecemeal through one title to the next. But if you author the compilation with NO chapters within the clips, each press of the skip button will jump to the end of the currently playing clip. At the end there will be a slight pause, then the next title (clip) should play. Rapid repeated presses of the skip button should display title/clip numbers advancing on screen, when you reach the number you want to view release the button and it should play.
Toast is a pain but sometimes a necessary evil on Mac, ditto the useless Apple DVD Player. You may just have to live with the quirks, they occur on Windows PCs as well. I find software players annoying and glitchy on both platforms. -
@ Orsetto:
Unfortunately authoring the compilation with NO chapters within the clips didn't make it possible to jump to the end of each clip by pressing the >>| button.
Without chapters within the clips I don't get any reaction if I press the >>| button. -
I tried a second standalone DVD player. Like the first standalone I mentioned, this one also facilitates jumping from title to title by pressing the >>| button.
The Apple DVD Player just doesn't facilitate this.Last edited by HitTheRoad; 11th Aug 2011 at 04:35.
DVD Player doesn't play menu
By nharikrishna in forum DVD & Blu-ray PlayersReplies: 6Last Post: 21st Mar 2011, 06:48 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 14:44 -
Can I Drive an Apple LCD directly from a DVD player?
By xmiinc in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2009, 21:49 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 02:05 -
DVD player doesn't read DVD
By hockey_fan_12 in forum Authoring (DVD)Replies: 1Last Post: 17th Nov 2007, 19:29
