Hi. I had this problem yesterday and after looking around the internet I could not find the solution so I started investigating it myself.
I found that the problem was being caused by a mounted iso. I was using magic iso (magicDisc) which starts with windows.
Here is how I fixed it.
Click Start, type msconfig and press enter, click the startup tab, untick the box for for your disc mounting software, click ok and restart.
(Windows XP users press Start, Run)
This could probably also be fixed by unmounting the drive but I tried the above way first.
If this does not work for you I suggest getting into msconfig/startup tab and clicking "Dissable All" and pressing ok, restart. Then try dvdflick again. If it works there is a conflict with something that is starting with windows.
Anyway. I hope this info helps somebody.
I may have posted this in the wrong place. If so, could an admin please move it.
Last edited by Bawn; 8th Aug 2011 at 15:31. Reason: I may have posted this in the wrong place
I've been having a bear of a time with the :
"53 DVDFlick: File not found"
This kept happening at the Generating Menus stage.
I was able to resolve this problem by creating a directory for my source files in the root directory, and shortening the file names of the source AVI's.
I am thinking that the file not found is related to the length of the file name, including path, when generating the DVD menus.
Trojan Virus=C:\FOUND.011\file0000.chk. - Problem Solved
By blinky88 in forum ComputerReplies: 10Last Post: 6th Feb 2013, 22:17 -
SOLVED:Mpeg2 Video (Movie cilp) to PAL DVD - sync prob using DVDFlick.....
By bahjan in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 10:03 -
no subtitles found by DVDflick ,AVS2dvd, FAVC
By sportflyer in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2010, 14:44 -
file not found in MPCHC
By hamdy in forum Software PlayingReplies: 3Last Post: 5th Nov 2009, 15:40 -
DVDFlick output file
By wristar in forum Authoring (DVD)Replies: 1Last Post: 14th Oct 2007, 13:58
