Results 1 to 10 of 10
    Aug 2011
    Holland, Europe
    I've succesfully converted (not encoded!) many VOB's tot MPEG-1/2 using MPEG Streamclip. But some VOB's just won't be converted. They can be encoded to DV, AVI, MPEG-4 or QuickTime, but simply converting them to MPEG ('Convert to MPEG') doesn't seem to work.
    What could be the reason? Is there a workaround?
    I'm working with: MacTheRipper, MPEG Streamclip 1.9.3b2, iMac 3.06 GHz Intel Core 2 Duo OS 10.6.7 MPEG-2 Playback Component Perian 1.2.2 VLC 1.1.10 (64 bits)
    P.S.: I'm using MPEG Streamclip to extract my favorite scenes from commercial DVD's. I convert the VOB's to MPEG-1/2's to be able to watch the scenes on my iMac in their original DVD-quality.
    You can try avidemux, open the first vob, under video and audio use copy, save as a mpeg-ps/mpg.
    Aug 2011
    Holland, Europe
    @ Baldrick:
    It works! Avidemux does the trick.
    Any explanation for this? Why can Avidemux do what MPEG Streamclip can't?
    I guess it has anything to do with the possibility Avidemux offers to save VOB's as MPEG-PS? And if yes, what does this tell about the VOB's MPEG Streamclip isn't able to convert to MPEG 2?
    Great.
    No, I have no idea. I don't use mpeg streamclip for vob conversions.
    Aug 2011
    Holland, Europe
    Okay Bladrick. To be sure: Is saving a VOB as MPEG-PS (in avidemux) the same as conversing a VOB to MPEG? There's no encoding involved? Do I get a losless 1-to-1 conversion?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    If you set the video and audio to copy mode it's lossless.
    Aug 2011
    Holland, Europe
    Thanks very much!
    Aug 2011
    Holland, Europe
    I've been too enthousiastic about Avidemux. Like I mentioned earlier, Avidemux helps me to convert the few VOB's I can't convert using MPEG Streamclip. But editing these problematic VOB's (before converting them to MPEG) is another cup of tea. After opening these VOB's in Avidemux I get a scrambled picture. This way it's hard to navigate to the parts of the video where you want to cut. Also there's no audio.
Name:	Schermafbeelding 2011-08-09 om 10.42.13.png
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    Export to mpg and then try edit in mpeg streamclip?
    Aug 2011
    Holland, Europe
    @ Baldrick:
    This does te trick! Thanks very much again.
