Hi, I need to shrink the length of a DVD production. Original AVI is on disk and my newly authored VIDEO_TS output.
I need to increased the total length of the DVD by 6 minutes and (impt) if possible to sync the subtitles at the same time too.
How can I do this?
I am practiced at using a good selection of raw and Cyberlink DVD editing/authoring tools, but obviously I seem to not know of a program that can do this all at once preferably without having to doing time consuming crop/extract routines.
I am interested in seeing where this thread goes on the topic.
All reasonable and experienced comments welcomed/needed.
	1) on one hand you say you need to shrink the length, then you contradict yourself and then say you need to increase it by 6 minutes. Which is it ?
 2) why do you "need" to ? It would help to know the background information
 DVD has strict requirements for frame rates, you cannot simply speed up or slow down and have it DVD compliant
 It's probably easier to add or remove content if you need a specific duration
	What's the frame rate of the source? I assume you're making an NTSC DVD since you're in Canada. It may make more sense to adjust the length of the subs -- you can do that easily with Subtitle Workshop.
	The subtitle comes from a 3rd party. It doesn't sync up with the video frames when I do that. It is NTSC.
	Then simply changing the running time of the video won't work either.
 Exactly how you adjust the subtitles to match the video depends on what's different between the two. Why is there a six minute difference? Because one has additional scenes? Because one is PAL the other NTSC?
  Video length Automatically increase after encodingBy darkstonecold in forum Video ConversionReplies: 1Last Post: 22nd Nov 2011, 22:53
  Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid lengthBy chindoo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2011, 20:51
  Problem Setting a Specific Frame Length in Sony VegasBy MolonLabe in forum EditingReplies: 6Last Post: 23rd Jan 2011, 12:59
  How to find out Frame Rate and Video LengthBy GSReddy in forum ProgrammingReplies: 0Last Post: 20th May 2008, 01:02
  Encoding MP3 causes the sample length to CHANGE?By Colmino in forum AudioReplies: 1Last Post: 26th Nov 2007, 21:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
