I am in the UK and I'm currently using AVS Video Recorded to capture the videos at 320x240, 29.97 FPS, 920.33 Kbits (basically, these values are all the software will allow).
Are these the optimal settings?
If not, what software should I use and what settings should I use?
Why the hell would you start another thread on the same exact subject?
https://forum.videohelp.com/threads/337550-Doubling-the-size-of-a-WMV-video-%28320x240-640x480%29 -
They're not the exact same subject? This way is also better for search engines in case people want to search for this issue.
video cam can suite 8mm tape/cassette
By happytony in forum Video ConversionReplies: 1Last Post: 24th Aug 2011, 00:33 -
From 8mm tape to Final Cut...no camcorder
By cecile in forum Capturing and VCRReplies: 18Last Post: 23rd Aug 2011, 23:53 -
8mm tape source filmed twice
By Dieu in forum EditingReplies: 9Last Post: 17th Nov 2009, 20:14 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 14:24 -
8mm camcorder tape playback suggestions?
By Bix in forum RestorationReplies: 8Last Post: 23rd Aug 2008, 02:02
