I have downloaded a HD video " B.mp4" from youtube,the information copied from KMP player is:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp4 2
Overall bit rate : 2 504 Kbps
Video #1
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Duration : 25mn 10s
Bit rate mode : Variable
Bit rate : 2 347 Kbps
Maximum bit rate : 5 410 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate mode : Variable
Frame rate : 25.000 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.102
Stream size : 606.7 MiB (94%)
I have another viedo A (H.264,much shorter than B.mp4) , and I have converted A to A.mp4(720p) , and then tried to merge it with the video above by AVIdemux2.5.
But only the A ,part of the merged video ,can be played normally ,the B part of the merged is failed to display.
I guess the format of A.mp4 didn't match the B fully. I have tried several conversion softwares including MeGUI(not skilled),but all without success.
Can anybody help me?
Thanks!
Have you compared the details from the part a? And most looks similar?
You can also try join with mymp4boxgui. -
My_MP4Box_GUI failed also.
A.mp4 converted by MeGUI is very similar to B ,one of the A's details is:
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
Video #1
Format : AVC
Format settings, ReFrames : 4 frames
Codec ID : avc1
Height : 720 pixels
Frame rate mode : Constant
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.008
I found that the mp4 download from youtube (not only B) can be recognized only by Avidemux,the other jioner softwares can not, this may be the crux of the problem.
Match Subtitles
By hbelouf in forum SubtitleReplies: 2Last Post: 27th Aug 2010, 22:49 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 05:10 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 20:50 -
how to match subtitle with hd movies ???
By abd640 in forum SubtitleReplies: 3Last Post: 19th Nov 2007, 18:48 -
Replacement for Music Match
By sdlehman in forum Off topicReplies: 10Last Post: 29th Jul 2007, 15:47
