  1. illusion Dictator
    Jul 2011
    In your Heart
    What is coolest (Maximum quality Remain) & hottest (Low File Size) DVD or Blue-ray ripper do you use or do you think???
    Pls, share here your experience my friendz..........
    USA
    I use Handbrake for encoding my DVDs to H.264 format for good quality and small file size. For ripping, I use AnyDVD and let it run in the background.
    And iqbal88, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
    Try to choose a subject that describes your topic.
    Please do not use topic subjects like Help me!!! or Problems.
    Thanks,
    Moderator redwudz
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    A "rip" is an exact copy of a DVD or Blu Ray with no compression or re-encoding. For copying DVDs I use AnyDVD and occasionally DVDFabDecrypter.
    I also use Handbrake to re-encode.
    Apr 2004
    Miskatonic U
    Quality versus Filesize is a trade off. Maximum quality requires high bitrates and therefore large file sizes. There is nothing you can do to change this.
    If you want the "MAXIMUM QUALITY !!@#!$!#@#!" the rip it and leave it.
    Anything after that is a trade-off between quality and size, and the answer comes down to your tolerance for what quality. Some still believe quality is achieved in a 700MB Xvid file.
    Read my blog here.
  5. illusion Dictator
    Jul 2011
    In your Heart
    Thanks,
    Moderator redwudz
    ThanX Bro, 4 your suggestion
  6. illusion Dictator
    Jul 2011
    In your Heart
    Anything after that is a trade-off between quality and size, and the answer comes down to your tolerance for what quality. .
    Bro I accept your understanding.
  7. illusion Dictator
    Jul 2011
    In your Heart
    thanX bro
