Yes.. LCD TV.
I have 25 HZ, Interlaced set as screen resolution and videos appear interlaced.
Results 31 to 43 of 43
Whereas when I had my HTPC connected to the new TV (Samsung), there was no way to set it to Interlaced.
now I'm really confused. I think you are using "interlaced" differently than how it's meant to be used
I think you mean there is a setting on the tv that is labelled "interlaced" ?
Because nothing in your setup should be interlaced. The display is progressive, all the content in the mediainfo of the files you provided is progressive -
The Toshiba is an LCD TV... flat panel... NOT CRT.
All I'm saying is that on my HTPC I have set the refresh rate at 25hz/interlaced and that helps output the video in a way that to me looks smooth. -
sorry , not sure what's going on...
but it sounds like you probably have more problems than just incompatible encoding settings -
Blahpwap: I have two questions the usb device you hook to your tv is it a usb stick as opposed to a usb hard drive with a power cord? The other is if you were to hook up this TV screen via a hdmi cable to your computer and play the video would it play smoothly on your tv screen?
I have a Phillips Divx Ultra Player with a USB slot and if I play files from a usb stick they are very choppy, if I play the same files with a usb hard drive with a power cord they play smoothly. Probably that isn't the issue you are dealing with. That WD Player sounds like quite a gizmo; I would get one if Future Shop Canada still carried them. -
Tom, I use an external WD My Passport HDD, with which I play movies fine on an HTPC. That isn't the problem.
I've sort of figured out what the problem for me is... I much prefer an interlaced image as I feel the movement is more smooth and easy on the eye. I am now trying to find out whether buying a streamer would allow me to output 1080p mkv files interlaced... -
I just extensively tested the new LCD TV with my HTPC and for the life of me I could not achieve the same excellent results I can on my old LCD TV.
The old LCD TV resolution is set at 1920x1080, 25hz interlaced and presents a very smooth picture.
I tried those settings and a dozen others on the new TV but I still get the most annoying judder and flickering no matter what I do.
Get MKV files working on Samsung LCD. I've tried everything! (I think)
By Zepwich in forum Video ConversionReplies: 22Last Post: 17th Sep 2013, 11:56 -
SD playback quality on LCD TV's
By Chris K in forum Newbie / General discussionsReplies: 20Last Post: 17th Nov 2010, 11:43 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 11:26 -
Is this a good LCD for 1080 playback?
By Engineering in forum DVB / IPTVReplies: 0Last Post: 16th Dec 2009, 17:42 -
Best Size/Quality for TV (PLasma/LCD) Playback?
By Rjupiter in forum DVD RippingReplies: 9Last Post: 26th Nov 2008, 22:18
