is there a difference between subtitles and closed captions? If yes, what?Originally Posted by VobSub Ripper
Results 1 to 12 of 12
Yes, the closed captions is a data packet inside the mpeg2 video stream and subtitles is a separate stream inside the vob file, see http://en.wikipedia.org/wiki/Closed_captioning#DVDs
ok, many thanks. Do the tools listed here all adhere to the correct terminological distinction or do some use the terms interchangeably?
And what would be the beginner-friendliest tool to check whether a VIDEO_TS folder on my HDD has subitles, CC or both, ... and to extract them?
PS: I can't recall MediaInfo ever display anything about closed captions (only subtitles) when being fed a VOB fileLast edited by lovelove; 6th Aug 2011 at 06:27.
You can get free subs from subscene.com. But sometimes they mention they have HI, that indicates they came from CC's.
thanks everyone, you have been a big help!
(note to self: HI = Hearing Impaired) -
CC's have sounds in them like 'sound of door opening.' Subs don't, except if they are made from CC's.
yes, first time I saw that, thank you. Strangely enough, the closed captions were not in VTS_02_1.VOB but in VTS_02_2.VOB ... (i.e. the 2nd 1GB file, not the 1st one).
SubRip says "Information: Closed Captions detected (2x)". Does anyone of you know if SubRip can display/export the CCs (given that it can detect them) ?Last edited by lovelove; 22nd Aug 2011 at 11:17.
If MediaInfo is reporting no closed captions, I don't have a good explanation for the absence of closed captions in some VOBs, other than than re-encoding, although you haven't said the video was re-encoded. (When video is re-encoded, closed captions would be lost, since encoders don't preserve the MPEG-2 GOP user data.)
Subrip can only read the flags in IFOs that indicate whether or not closed captions are present. It can't detect them just by examining the video. Note that in some cases, the CC flags in an IFO can be wrong. MediaInfo reports regarding CCs in video files are more reliable.
Subrip can't extract closed captions in .srt format. If you want closed captions saved in .srt format, I recommend that you use CCExtractor GUI (recently updated). VOBSub (last updated in 2002) is also supposed to work for extracting closed captions from DVDs, but I have never used VOBSub.
hdmi does not support closed caption?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 29th Jun 2010, 11:49 -
Closed-caption subtitles in UK
By kasfig in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2007, 12:50 -
terrible problem with adding subtitles to closed caption DVD, please help
By jimdagys in forum SubtitleReplies: 15Last Post: 21st Oct 2007, 03:52 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 03:50 -
watching dvd on pc - closed caption subtitles
By kasfig in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2007, 12:20
