Hi,
I am trying to insert a stopwatch timer into a video clip using Premiere CS5.5 and the native timecode video effects do not give me the required display. I would like to get a timer that will display elapsed time to tenths and one hundredths of a second and start at a specific point.
Searching around a bit it seems that there used to be an Adobe plugin called DV Date distributed by a compant called Digital Video Engineering, however they seem to no longer exist of have changed name.
Can anyone please assist with the insertion of the timer or let me know of a suitable plugin for Premiere CS5.5. The native timecode video effect in Premiere gives the elapsed time in the format of "hh:mms:frames" whereas I need tenths and one hundredths of a second.
The timer is for sporting event videos where fractions of a second play a role.
Thx
Do you have after effects? You can overlay and display hundredths of a second with it's internal timecode plugin
The DV Date homepage seems to work for me. http://www.dvdate.ru/Searching around a bit it seems that there used to be an Adobe plugin called DV Date distributed by a compant called Digital Video Engineering, however they seem to no longer exist of have changed name. -
What's the problem with incorporating a split-screen or box wipe of your preferred type of stopwatch, running in time with the sports footage?
Inserting subtitles in a Matroska
By Jomapil in forum SubtitleReplies: 5Last Post: 14th Apr 2012, 12:54 -
HELP!! Inserting Subtitles to an .AVI
By poopy-underwear in forum MacReplies: 5Last Post: 13th Aug 2008, 19:53 -
Inserting Photo into Video
By Nightcrawler in forum EditingReplies: 1Last Post: 26th Jan 2008, 00:04 -
Inserting subtitles into a movie
By aussiekev in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 06:13 -
Inserting Opening
By zirkov in forum Video ConversionReplies: 2Last Post: 27th Jul 2007, 13:53
