I need help please!! I have an Optiarc DVD -R, AD7170a, which I flashed after re-installing Windows XP
When I look up in Device Manager, shows the correct Optiarc, and that its a DVD R, but, under properties, it onlty shows information for CD recording.
I installed Nero 7, and it doesnt recoginized the DVD drive, just the CD. I also used IMG Burn, and it sees it, but wont burn.
So I need to know how to get it back to using the DVD again. The DVD did work before I re installed XP.
According to Google that drive has a long history of this problem. Might be time to simply replace it.
I can confirm that. We had the same drive in a recording studio DAW, and it caused hordes of problems. Took days to figure out what the problem was.
i7 920@3.3|P6T6 WS Rev|12G DDR3@600|1300wABS|GTX285SC|4xWD1001FALS|2xWD1501FA SS|3x7K3000|LSI 9211-8i|IntelPro100|2xSamsung DVDRW|Win7x64|Slave: AMDX2 4200@3.0|A8N SLI-Prem.|ATI HD2400XT -
Have you tried removing the drive in Device Manager and restart the system to see if that helps? If that doesn't work, you might try deleting upper and lower filters values.
Bevills1, I will try that and let you know. Thank you everyone for your feed back.
Sony Optiarc DVD RW Drive writes but verify errors???
By bahjan in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Jan 2012, 09:33 -
WD External hard drive no longer works with my LG DVD Player
By KarlKarlson in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Feb 2010, 13:16 -
Sony and Optiarc DVD writers
By anfield7 in forum DVD & Blu-ray WritersReplies: 2Last Post: 1st Oct 2009, 23:44 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 18:19 -
sw can not see lightscribe drive, but CD/DVD burner works...
By jwjr417 in forum DVD & Blu-ray WritersReplies: 23Last Post: 7th Mar 2008, 18:03
